![]() Drives: blue 08 hb Join Date: Dec 2008
how long before replacing brakes ?
I have a 2008 hatch with about 35,000 miles of city/hiway mix. Anybody have an idea how long the brakes should last ? These will start squealing before they get to thin, won't they ?
![]() ![]() ![]() Drives: 09 Meteoric Metallic 3 door HB Join Date: Jul 2010
It depends on how you drive and your use of the brakes.
Obviously more rough and repeated use of the brakes will cause them to wear faster. |
#3 | |
I will add that it is not nessarily how often you use the brakes that wear them quicker but, how you uses them. If you frequently wait until the last second to apply the brakes and then apply hard pressure on the pedal, you will ware brakes out fast. What you have to do is gently apply the brakes sooner to gradually come to a stop without the need to apply heavy pedal pressure. Granted, this is not alway possible but, should be practiced as often as possible. It will make them last much longer. |
This ^^^^^. I also think having a manual transmission helps re making the most of this. I hear the old 'brakes are less expensive than an engine', but I'm getting many miles out of both and I don't rev the engine very high when downshifting during this scenario.
#5 | |
![]() ![]() ![]() Drives: '08 LB, '07 WRX Join Date: Jan 2009
Our yaris sees about 75% highway usage. It currently has just under 65k miles and the brakes are still in great shape
Modded Moderator
Please check what section you are posting in when starting a new thread. I've moved this to the correct section.
Side note- Im 106k miles and on original brakes, still fine. |
With such a light vehicle, under normal driving conditions it should not be uncommon to easily get 60-70K+ miles out of a set of brakes.
And yes, modern brake pads usually have indicators built in to where they will make noise when it's time to replace them. If you're curious as to how much pad you have left, go by any tire/brake shop and they will give you an estimate based on the percentage left...
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Aug 2011
Rule of thumb is when the friction material is down to one millimetre thick (thickness of a dime), it is time to change the pads or shoes.
Roy |
![]() ![]() Drives: 2008 yaris hb Join Date: Mar 2011
just did mine with 150,000 miles. 95% highway
![]() Drives: 2009 Yaris 4 door hatch Join Date: Dec 2008
My 09 has 121,000 miles, changing them this weekend.
toyota
im at 110,000 km still on original but need replacement next summer..
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
102,000 miles still had some pads left but rotors were warped and rusty so I upgraded to corolla calipers and pads and bigger rotors.
| Brakes Squealing! | cmkennedy | New England | 1 | 10-30-2011 06:08 PM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
| Metal scratching from brakes | alt_k1ll3r | DIY / Maintenance / Service | 16 | 02-11-2010 12:04 AM |
