Old 11-15-2010, 09:56 AM   #1
yaris2007_22
Drives: Toyota Yaris 2007
How to adjust parking brake?
Anyone know how to adjust parking brake for yaris 2007 sedan?
yaris2007_22 is offline   Reply With Quote
Old 11-15-2010, 11:44 AM   #2
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Go here:
http://yarisworld.com/forums/showthread.php?t=365
Then go here:
http://www.yarisworld.com/forums/showthread.php?t=12333
Bada bing, bada boom- faster than search (**Hint**)
Old 07-21-2013, 11:57 PM   #3
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Can't view the photo's?.Old thread I guess.
Did the adjustment a few days ago.The drums came right off!,no issues.Only moved the star gear about 4 "Clicks".....did some good,but not that much for the e-brake.I did notice some enhanced braking however!....try again next time.Did not want to put Too much drag on the drums.
frog13 is offline   Reply With Quote
Old 07-22-2013, 12:14 PM   #4
swidd
Drives: Yaris HB
I tighten the star wheel way up, to where I can barely (if at all) move the wheel, and obviously can't get the drum off in several thousand miles. It has no effect on MPG as far as I can tell.
swidd is offline   Reply With Quote
Old 07-22-2013, 05:38 PM   #5
frog13
Tw200--excellent!
Swidd......tightened the star until you could barely move the wheel?.....Now,are you saying after adjustment,you place the wheel back on and attempt to rotate or you are trying to rotate the unit with just the drum on? (much more difficult to rotate via the drum vs. the wheel being on.).If going that tight it would seem you would "burn-up" the drum and or the pads ASAP!!. Are you also adjusting the "nut" under the e-brake handle inside the car?;if so,is the plastic(s) a PIA to remove for this?. TIA
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 09:50 AM
I dropped something down in my parking brake slot... Boonespeed Cosmetic Modifications (Exterior/Interior) 12 08-11-2009 10:31 PM
Parking Brake Shoe Adjustment bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-14-2009 03:26 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 09:14 PM
Parking Brake Adjustment Q's Lafiro DIY / Maintenance / Service 3 04-13-2009 09:19 PM
