![]() Drives: 2005 Vitz RS, NCP91, Manual Join Date: Jun 2013
Yaris/Vitz RS hatch DIY gas struts repair
Hey guys. When opening the boot (trunk) of my 2005 Vitz its started to stick and does not open all the way up.
Any ideas on a DIY fix? |
That means that it is time to replace the gas struts.
Cheers for that. Was just wondering if there was a DIY way of repairing them. Will take the car in and get it done.
#4 | |
If you do go with aftermarket ones, make sure that they have an equivalent lift rating (~90 to 100 lbs) and that they are the dampened type (which open quickly and then slow down as they approach their full open position.
Problem, officer?
Drives: '06 Yaris 5DLB 1.5 Join Date: Oct 2010
My hatchback had this problem, particularly on a hot day.
I fixed that by rubbing grease around the strut shaft and then sprayed WD-40 onto near the opening where the shaft glides into the strut body. (the grease will dry out after around 3-4 months though) |
| DIY : changing the Oxygen / O2 sensor on Yaris hatch MANY PICS | auxmike | DIY / Maintenance / Service | 50 | 12-10-2024 01:39 PM |
| DIY: Hatch Popper using Scion IQ Hatch Handle (2006-2011 Liftback) | CTScott | DIY / Maintenance / Service | 15 | 12-30-2015 07:27 PM |
| Rear Hatch Gas Springs - don't lift anymore | mrrock | General Yaris / Vitz Discussion | 21 | 09-28-2011 06:50 PM |
| Rear Hatch Gas springs - don't lift anymore | mrrock | General Yaris / Vitz Discussion | 0 | 01-14-2009 11:09 PM |
| DIY: Yaris Hatch grill block/air dam | yarswiss | DIY / Maintenance / Service | 0 | 10-26-2008 07:52 PM |
