VW rims on Yaris?
will the VW rims work on Yaris ..14 inch up.
4x100 VW wheels will fit. Many VW wheels have a ET33, ET35 or ET38, so they will tuck into the car 1cm or less than OEM wheels on a Yaris.
i thought lower the ET number the more the wheel goes out more flush with the fender...correct me if im wrong. Running a 35 to 38 ET should be fine i would think....and ty for the info, also anyone try and actually run VW rims on Yaris, if so pics would be great.
#4 | |
Make sure the center bore size is the same size, 54.1mm, or bigger. If it's smaller, it won't work.
Not if it's smaller than 54.1mm. If it's smaller, you'd have to get adapter wheel spacers that goes from less than 54.1mm to 54.1mm. My friend had to do that with his VS-XX. If it's larger, then you can get hubcentric rings (don't have to, but it's suggested).
I always reverse the direction of offset. VW are typically 57.1mm for bore.
Yes. That should be an easy hubcentric ring size to find.
yak
Drives: 2007 5 dr yaris Join Date: Jan 2009
I'm running 14" VW Rims & 205 60 14 rubber
cheers yak |
A singular example of the very newest model/generation of Bug/Beetle coupe (not convertible) was parked next to my Yaris at Starbucks today. It had what was trying to be a modern version of those original saucer/observatory dome/half sphere Beetle wheel covers on it. I liked the previous 'model/generation' of Bug/Beetle, but not this one....and the wheels don't help....the totality/result = an ugly mess....might be markedly different on a Yaris, though......would certainly be unique
#13 | |
![]() ![]() Drives: white yaris hatchback. Join Date: May 2011
VW wheels totally work!
my wheels are 4x100 BBS RM that were a factory option on MK2 (1985-1992) VW gti's. naturally i made my wider but still no issues just make sure the offset is good and you wont have a problem!
http://www.instagram.com/dino_eggxo |
| 08 Yaris w/18" rims need advice | greenbid | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 03-13-2012 11:43 AM |
| OEM yaris rims | frog13 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 07-01-2010 06:07 PM |
| Silver Yaris w/ Black rims Spotted | ScubaSteve | Canada | 3 | 07-05-2009 12:11 PM |
