Old 03-29-2007, 05:26 PM   #1
deebrown
Drives: Sedan
Sandbags in Trunk?
I'm having a problem with the yaris being blown around in the wind on the highway - i was thinking about putting sandbags or free weights in the trunk of the car (it's a sedan) to weigh it down (and thus hopefully making it more stable). Has anyone done this and, if so, what was the loss on mpg?
deebrown is offline   Reply With Quote
Old 03-29-2007, 05:31 PM   #2
pc1x1
Drives: Yaris 2007 Liftback (Jan 07)
Common sense more weight = less mpg. What you can do is a ratio, Power/Weight = Power/Weight + sandbacks, then check MPG and multiply it by your normal MPG.
pc1x1 is offline   Reply With Quote
Old 03-29-2007, 05:35 PM   #3
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
You so SMART!
Nutzoids is offline   Reply With Quote
Old 03-29-2007, 05:40 PM   #4
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
Been there, done that! and i have a LB it's scary man! 120K/h and the wind moves you!!!
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 03-29-2007, 07:36 PM   #5
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
what i have seen is tires that respond to wind but idk theres not much you can do. you would have to put a lot of weight wouldnt you?
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 03-29-2007, 07:53 PM   #6
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
I have roughly 150 pounds of stereo junk in the trunk of my sedan, and all it helps to do is increase the body roll of your car.
If you want to stop getting pushed around by crosswinds, you have a few options:
A. Buy a bigger car
B. Lower that beech!
C. Follow option B and also buy some bigger rims & really wide low profile tires
D. This option is if you refuse to lower it...buy wide low pro tires and rims to mount them on, buy sway bars,struts,and a strut tower brace...these will help stiffen the car up a little bit and perhaps help with the wandering in crosswinds.
E. Just forget the other options and lower it because it is the best option second only to option A.
Old 03-29-2007, 07:58 PM   #7
BailOut
Steals terrorist's lunch
BailOut's Avatar
I'm curious if you folks experience higher winds or just different vehicle behavior than I do.
The area I live in gets 90 MPH winds several times per year and lots more days of gusts up to 75 MPH and while I have definitely felt the wind resistance and the Yaris leaning, maybe even being pushed a touch, I have never even come close to getting blown out of my lane, or even moved that much in it.
Is it just the leaning or feeling of being pushed that bothers you folks so?
- Brian
Share the Road
Old 03-29-2007, 08:01 PM   #8
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
I lowered mine 1.9 front and rear and it made a huge difference on the highway. Much better.
SPONSORED BY
Old 03-29-2007, 08:41 PM   #9
deebrown
Drives: Sedan
How to lower car
Ok, can anyone tell me how to lower the car and how expensive such a process is? Also, my last car was a dodge neon (very low to the ground and no wind problems) but i was constantly "bottoming out" the car as it was so close to the ground - do any of you who have lowered your car have this problem?
Thanks,
Dee
Old 04-02-2007, 12:00 AM   #10
Lillydot
Absolutely Red!!!
Lillydot's Avatar
Drives: 07 A/T Yaris Liftback
my car shifts lanes when the winds gust really high. i live by a beach, and sometimes i might be going only about 40 and my car is getting pushed. when i'm speeding down the pike at about 70 mph or so, i've almost gotten into an accident more than once. the faster you drive, the less room you have for error, so even getting pushed a few inches can be a scary experience. my last car was almost the same shape (focus 2dr hatchback) and had performance tires. i didn't have a problem with being pushed by the wind as much then. i think i'm gonna try switching the tires and see how that works out.
Lillydot is offline   Reply With Quote
Old 04-02-2007, 12:11 AM   #11
brickhardmeat
Lonesome Cowboy
Chop Top would be way cool ...but I'd have to sit on the floor
SPONSORED BY
Old 04-02-2007, 03:45 PM   #12
spkrman
Drives: 1
I assume so?
Grab the wheel, and stay in your lane, I never had any issues with it... even when passing a semi on a windy day 100% stock.
With the dubs on/225 tires, much better!
Old 03-29-2007, 09:21 PM   #13
Razr
YRS WHOR
Razr's Avatar
Drives: White 2007 Yaris E-Limited 5dr
I'm curious - there's a couple of threads on this subject and a number of posters suggesting that you fit swaybars..
Do your North American Yarii not come with an OEM front swaybar??!?
Here's a pic of the one that came standard on my liftback:
Razr is offline   Reply With Quote
Old 03-29-2007, 09:27 PM   #14
brickhardmeat
Lonesome Cowboy
chris did a "how to" on his tanabe spring install, whatever springs you use go in the same, you could probably get them installed for about 200. dunno, luckily I have a friend who helped me out, tools and all, it's not a big deal just don't let the car fall on your head
SPONSORED BY
Old 03-29-2007, 09:43 PM   #15
Spades
The Hated One
Spades's Avatar
I haven't checked to see if my US sedan comes equipped with a front swaybar...I assumed it hadn't due to the low cost of the car and pronounced body roll.
I haven't noticed much problem being pushed around from lane to lane either...I notice a strong gust puts some resistance on the steering wheel, but it never was strong enough to even come close to moving me into another lane.
Old 03-29-2007, 11:07 PM   #16
sf180th
Back in USA in days!
sf180th's Avatar
Drives: 07 Yaris S Sedan
Send a message via Yahoo to sf180th
I have a Sedan and yes the American models to come with a front sway bar.
Kazera KZ-V Silver Rims, with 215-35-18 Kumho ESCTA ASX, TRD Springs, TRD Sway Bar, Fujita CAI, Blitz R-Vit i-Color, Blitz Throttle Controller, Megan Header, 2.25 Stainless Cat back Exhuast, 50 Series Flowmaster muffler, 6000k HID.
sf180th is offline   Reply With Quote
Old 03-29-2007, 11:13 PM   #17
Spades
The Hated One
Spades's Avatar
yes, but does yours have the swaybar because it is an S coupe? or do they all come with them?
Old 03-29-2007, 11:19 PM   #18
Razr
YRS WHOR
Razr's Avatar
Why don't you turn your wheels to full lock and take a look Spades :)
trunk sub pix! drell42 In Car Entertainment + Electronics (audio / video / alarm) 21 07-26-2009 10:25 PM
Electronic Trunk Release Problem jonr0613 DIY / Maintenance / Service 5 09-08-2007 07:13 AM
Help with Amp Ground in Trunk Meldav86 In Car Entertainment + Electronics (audio / video / alarm) 5 03-22-2007 02:31 PM
Trunk issue Lowfront In Car Entertainment + Electronics (audio / video / alarm) 1 09-24-2006 07:55 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 02:26 AM
