Old 04-01-2007, 06:18 PM   #1
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
anyone else see this yet????
http://cgi.ebay.com/ebaymotors/2007-...QQcmdZViewItem this is something that can be bought for probably 5 bucks. can it be done with results????
http://www.carid.com/toyota-accessories/
site has a FEW interesting yaris items.....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 04-01-2007, 07:09 PM   #2
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Funny you should post that up... just did the same thing to my Armada, after a member on the Armada forums posted that same question up.
FYI - save some money, it only took two 5/16th plugs (for throttle body) and one 8" long 5/16ths rubber heater hose from the parts store. Less then 5 bucks.
Old 04-01-2007, 07:52 PM   #3
Ogredude
Ogredude's Avatar
Drives: 2007 Red Yaris RS
I did this mod to my mazda 2.5L MX-6 when i installed some Intake spacers, Basically it was bypassing the IAC sensor, so the car thought it was running cold all the time because theres no coolant flowing through the throttle body to read the temp, therefore more gas was injected, and possibly timing advanced
- side effects were HIGH IDLE all the time, it was annoying, but i noticed a slight increase in power in the high revs
In the end your making the computer think the intake temperature is cold so it will be constantly running Rich
There are many other BS mods on Ebay like the resister that emulates intake air temperature is coldest at the MAF making the timing more advanced again
All these mods will probably increase your gas mileage and increase pollution
Ogredude is offline   Reply With Quote
Old 04-01-2007, 07:56 PM   #4
Chris07LB
Chris07LB's Avatar
That doesnt go for every car or truck though.
It's main function is for cars/trucks operating in the colder parts of the country.. My Armada for instance does not have a sensor in the coolent cavity in the TB.. its plumbed that way so the TB does not ice up.
It doesnt get "that" cold here in Jersey on its worse day. Plenty of Titan and Armada owners have reported back with positive results. How this will turn out on the Yaris, no idea.
Old 04-01-2007, 07:34 PM   #5
spkrman
Drives: 1
so this is useful?
Old 04-01-2007, 07:36 PM   #6
Chris07LB
Chris07LB's Avatar
Ill know once the weather gets hot out, and I have my long summer commutes. It makes sence on paper why it would work, so time will tell if it actually does.
Old 04-01-2007, 07:43 PM   #7
Dragonacc
Drives: 07 Yaris LB, 70 Mach 1, 84 5.0
It's a good summer time mod. It won't gain 8 hp like the ebay ad says, but you might pick up a couple on a hot day.
Just remember to undo it in the fall/winter if you live someplace that gets really cold.
Dragonacc is offline   Reply With Quote
Old 04-01-2007, 09:19 PM   #8
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
If that thing does prove itself to work on the Yaris, I'd be down to get those parts and do it myself (but definitely after some one else) =P
Old 04-01-2007, 11:04 PM   #9
365Motorwerks
Drives: Small and Black
Just try it you can always swap it back just buy the parts for the hardware store like Chris07LB it's nothing special unless you dont want to drive to the store....Matrix guys have been doing it for a while that's where I heard about it..like the rest of you it does sound like it should work, 8hp? Who knows I would just go with the butt dyno
365Motorwerks is offline   Reply With Quote
Old 04-01-2007, 11:04 PM   #10
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
it's sound so good, not bad for $20 bucks, give it a try.
jamal1984 is offline   Reply With Quote
Old 04-01-2007, 11:13 PM   #11
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
yea i did this on my last car and had no noticable difference.....the air is moving too fast for this to effect anything.....
this is definately going to vary per vehicle like chris said............and that almost seems like negative results when the iac sensor is located right at the throttle body and caused the conditions that were described......
I dont think its the worth the effort and time given my past experience but if anyone wants to try it out feel free.....
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Old 04-02-2007, 06:22 AM   #12
Chris07LB
Chris07LB's Avatar
Alright folks, ill give it a go.
Quick trip to the store later that is... not 20bucks on eBay.
Old 04-02-2007, 06:36 AM   #13
punch
punch's Avatar
guys read the dyno sheet he posted, 8hp was with this mod, ported throttle body, and egr mod...on a 300+hp camaro
punch is offline   Reply With Quote
Old 04-02-2007, 06:40 AM   #14
Chris07LB
Chris07LB's Avatar
Old 04-02-2007, 11:40 AM   #15
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
let us know what materials you bought later.....
Old 04-03-2007, 03:35 PM   #16
Vic-2NZFE
Vic-2NZFE's Avatar
Drives: Yaris 2NZFE
Mod
It's a Vitz!
Vic-2NZFE is offline   Reply With Quote
Old 04-02-2007, 12:56 PM   #17
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
this cant be good for you car... ur car's engine management got a purpose.. running rich can definetely damage ur engine on a long term run..UNLESS ur running one wicked ass oil in there...
Old 04-02-2007, 12:58 PM   #18
Chris07LB
Chris07LB's Avatar
Has nothing to do with it. READ thru the post here again, and see exactly why it can and does get bypassed.
