![]() ![]() Drives: TOYOTA YARIS S 2009 Join Date: Dec 2013
Change location of trunk lamp
I just discovered that the trunk cargo lamp has the same dimensions with the emergency door panel of rear door hook...and I just pelpaced the small door panel with the trunk lamp...this is the result...enjoy
Umm.. but that's not effectively lighting up the trunk space though...
If your trunk is full this lamp just not exist....for hatchback...
That's wild that it is the same dimensions. I have been meaning for ages to add one up at the headliner, as I often find that my side one is blocked and I can't see.
I have still the option to plug in another lamp to the previous spot...
When I find another probably I do it... |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
That looks like a clean install, nice going!
How did you run the wires? I know that the lamp on the side is almost useless when the back is full on the hatchback. I've thought about trying to add some light elsewhere. |
The wire is very easy to run with the other wires of rear wiper...when remove the door panel first of course...
So did you move the light or add it on for more lighting? If you had both you would have the best of both worlds...you might blow a fuse though.
advocatus diaboli
I did the same thing a couple of years ago but with an extra bright LED panel I ordered on Ebay so I have an extra light in addition to the one on the side. I tapped into the existing lamp so they both come on together.
nice!...it will be on my to do list...
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 02:50 AM |
| Planning first oil change @ 500 or 1000mi | schleppy | DIY / Maintenance / Service | 39 | 07-09-2010 07:28 AM |
| LED Change for the AT Shifter for a Liftback? | omendt | Cosmetic Modifications (Exterior/Interior) | 3 | 06-24-2009 11:53 PM |
| Trunk issue | Lowfront | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 09-24-2006 07:55 PM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 02:26 AM |
