Mr. 155 and climbing
Deatschwerks Fuel Injector Service Review
I have a set of Scion Tc injectors that I picked up. Since they could vary between 330-370cc and they have been sitting for a while so I decided to get them flow tested and serviced. I chose Deatschwerks as I have received solid input from several folks about them. They charge 20 bucks per injector for their Dynamic Service.
deatschwerks injector services I am shipping them today and will let you know how it seems to go.
Got the call yesterday and they are all wrapped up. Ended up being 335cc avg. Once I get them back I will post up the results sheet. These may be ok for a street tune, but not the LSRs so I will need to pick up a set of 800-1000cc injectors. I know my current 1zz injectors are 240cc and I am maxing them out at 5200 rpm already at the 210/210 point on vp100. 190/190 on pump.
Don't go 800-1000cc they are to big I would say some 440cc should be fine plus if you have raised the fuel pressure they will be flowing more. I am running 440cc injectors with a 58psi/4bar fpr and the injectors are flowing 508cc. I may switch out my fpr for a 3bar/43.5psi fpr because my fpr is rising 1:1. I am running an AEM 300lph fuel pump 5.0motorsport 440cc injectors and a blowerworks fpr all on a return fuel system handling 10psi richly.
I ran 635cc injectors at 24psi. Never even approached max duty cycle, and idle was a little rough. You'll be in trouble with 800+.
Alright. Good to know. Thanks guys.
Looking like I will go with the ID725 set since they most closely match my future needs.
I should be able to post up the results sheet by tomorrow evening. The package is sitting at home and I am stuck 200 miles away due to storm Vulcan.
I received my injectors back from Deatschwerks while I was away on business travel. Here you will see that they professionally pack the injectors after the service and provide an installation lube. They gave me a call prior to charging my card which was a nice touch to also confirm as well that the shipping address had not changed. They were pleasant and knowledgeable on the phone while speaking with them.
| Fuel Efficiency and the Yaris | BailOut | Fuel Economy Forum | 327 | 01-03-2026 12:44 AM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 04:34 AM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| Last Fuel Bar | andaconda | Fuel Economy Forum | 37 | 04-29-2009 03:35 PM |
