Old 07-18-2009, 12:29 PM   #1
Big Grim
Drives: 2008 Yaris
Oil: Is there a suggested type in the manual?
I recently picked up a used 2008 Yaris and it's time to change the oil. The owner's manual was absent when I made the purchase, so I can't RTFM and get the answer. :(
Can anyone tell me if there is a preferred type of oil to use for the engine? 5w30, etc?
Thanks!
Big Grim is offline   Reply With Quote
Old 07-18-2009, 12:32 PM   #2
PatrickJohnson
Drives: 2008 Yaris LB
5w30 is the recommended oil in the manual.
PatrickJohnson is offline   Reply With Quote
Old 07-18-2009, 12:34 PM   #3
Big Grim
Drives: 2008 Yaris
Thanks Patrick!
Old 07-18-2009, 07:32 PM   #4
BLH
Drives: 2007 Yaris Sedan
I my 2007 also has the information printed on the oil filler cap.
BLH is offline   Reply With Quote
Old 07-19-2009, 03:09 AM   #5
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
My owners manual specs 5W-30 ILSAC oil-and states 10W-30 can be used if 5W is not available.
There was a TSB issued however that recommends ILSAC GF-4 oil and approves 5W-20 oil for use in the Yaris's 1NZ-FE engine. So to make a long story short you could run any of these grades produced in the last several years by any reputable manufacturer and be OK, even while under warranty.
I love it when it when they make it easy for the consumer. VW for example is a PITA with their oil requirements.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 07-19-2009, 02:27 PM   #6
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Any oil with the API "Star" symbol on it also meets ILSAC GF-4 specs.
Tags
oil change
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 02:43 PM
Rim Weights bosbik Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 11-14-2009 07:42 PM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 02:55 PM
Help with oil viscosity (engine and gearbox) yaris 1.3L, and service manual! toyo DIY / Maintenance / Service 5 02-25-2009 12:55 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
