Drives: toyota yaris Join Date: May 2010
Air conditioning not getting cold
Dear Everybody!
We have a 2004 toyota yaris 1.3 vvti with the air con. We are in the uk and its a uk car. For some reason the AC is now no longer working. The blowers blow air, fans working etc, but when you press the AC switch, the green light comes on to tell you its working, but no cold air comes out at all. I have checked the fuses in the engine bay, and all are ok. Are there any other fuses in the car etc I have missed? Does anyone have any ideas what it could be? There is no evidence of a leak of coolant gas, and the engine bay is clean. What can I do to check / try to find the problem, as its now driving me mad, and I would like to get it working, so that when we have a few more hot days, we dont boil in the car!! Thanks in advance! |
Probably should just take it in and have an A/C service check. 6 year old vehicle, chances are pretty good you've lost your coolant. Since this is a gas, you will not be able to perform a visual inspection for leaks.
Half a Bubble Off Plumb
Yep. If you regularly watch the sight glass in the return line from the condenser to the evaporator you'll see bubbles when it's getting low, but when it's low enough to not cool you won't see anything.
black shark
Drives: black toyota yaris t3 sprit Join Date: May 2010
when they redo the gas for you, ask them to put dye with the gas so they will see if there is a leak for you,
www.justbabynappies.co.za |
#5 | |
![]() Drives: Toyota Yaris yr Join Date: Jan 2014
Did you find out what the problem was!? |
#6 | |
I hope you didn't have to pay for each replacement!
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
