Drives: vitz 2007 Join Date: Mar 2014
speedo meter not getting dim
hi i have vitz 2007 model automatic transmission. i am facing a very unusual problem i.e my speed meter lights are not getting DIM when the parking light or the head lights are turned on in the dark light although the digital clock display goes dim when the parking light is turned on. though the speedometer light use to get dim be four this problem. i have tried removing the cable terminal of battery and speedometer but still the problem is same.
Ok, not sure this will help at all and I actually didn't drive my yaris today to check but this is true in most cars anyway. (it's on my corolla at least)
there is a dimmer switch on the left hand side that may have gotten turned all the way up and thus you aren't seeing a difference. you may want to just check to see if that dimmer switch got adjusted before really digging in too deep. (I wish I had driven my yaris today) |
toyota
going with dimmer switch maxed out as well..
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
The vitz does not have a dimmer rheostat, like our USDM Yaris do.
To change the dimming level: Press the odometer mode switch from Odometer to Trip A to Trip B to Dimmer Level Hold the odometer mode/reset switch in for more than one second to change the level. When the battery is disconnected the cluster automatically goes back to 100% brightness mode.
#5 | |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
However, why do i get the feeling the OP has optitron? Out of topic: why do i get the feeling CTScott is not a real person rather a very smart computer AI program? He knows almost everything from cars everywhere. Hahaha |
#6 | |
