Old 02-21-2013, 05:32 PM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Removal of the door panel
There is a rattling noise coming from my drivers side door every time I close the door or hit a bump. does anyone have a diagram or set of instructions for removing the door panel?
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 02-21-2013, 05:52 PM   #2
There's a thread in the DIY section called something like "30 second door panel removal".
Old 02-22-2013, 01:33 PM   #3
Golddeenoh
Golddeenoh's Avatar
http://www.yarisworld.com/forums/sho...+panel+removal
found it thanks
Old 02-24-2013, 02:34 PM   #4
Golddeenoh
Golddeenoh's Avatar
well i fixed the rattle in the door, apparently this bracket had come lose where it has foam gluing it to the outside door panel.
i put a few dabs of super glue on the foam and pushed it back where it was, and for added redneck assurance, some duct tape.
Old 02-24-2013, 02:39 PM   #5
Superglue is only for non-porous materials. I would use Automotive Goop instead, which will do a good job of bonding it back in place.
Old 02-24-2013, 03:58 PM   #6
Golddeenoh
Golddeenoh's Avatar
its was dry rotted looking and torn, the duct tap should hold it together. since my budget for repairs right now is 0 i will have to stick with what i did instead of acquiring something else. thanks for the info :D
Auto Transmission removal artichap DIY / Maintenance / Service 14 10-23-2012 10:27 PM
99 Vitz Hatchback rear outer door handle removal deadalus DIY / Maintenance / Service 3 09-06-2010 02:02 AM
Removal of the Factory Integrated Source sqcomp In Car Entertainment + Electronics (audio / video / alarm) 7 08-24-2010 12:44 AM
Weight Savings - Removal, Reduction, Reminder.... TRD_Yaris Performance Modifications 17 08-12-2006 02:07 PM
