Old 10-02-2013, 10:05 PM   #1
KTS
KTS's Avatar
Drives: Vitz RS
ECU Extension Harness???
Good day everyone, let me start by saying what a great community this is I have already learnt so much from just reading through the forums.
I recently purchased a 2007 Toyota Vitz RS 1.5L Manual.
I want to install an AEM EMS-4 but I do not want to cut or splice into the original wiring harness. I have contacted AEM and Tweak'd Performance with no luck as they are saying they do not have the connectors for the 2007 Vitz RS. Although Boomslang makes a Patch/Extension harness for the vehicle compatible with the EMS4 I personally thing their price is too much (nearly the cost of the EMS-4 itself).
This leads me to the following questions I hope to get answered;
1) Athere any other companies that can make the Patch/extension Harness?
2) Is there some place that I can purchase the Boomslang Harness at a resonabe price?
3) Is the USDM Yaris and the Vitz RS have the same ecu connectors.?
Attached are pics I recently took of the ECU and connectors in my 2007 Vitz RS.
Any and all assistance will be greatly appreciated.
KTS is offline   Reply With Quote
Old 10-02-2013, 10:12 PM   #2
The US and JDM ECM connectors are the same. The cheapest solution is to make your own. I made one for my AEM F/IC using a junkyard ECM harness ($120) and an ebay ECM purchased for $35.
Here's an article I wrote for Micro Image on it:
http://microimageonline.com/forums/s...o-expensive%29
Old 10-03-2013, 05:04 PM   #3
KTS
KTS's Avatar
Drives: Vitz RS
thanks a lot for that info was thinking of what you suggested.
Thanks again.
Old 10-04-2013, 01:10 PM   #4
We are a Boomslang dealer and an AEM dealer. I would work with you as best I can on the pricing. Contact Micro Image at sales.microimage@gmail.com
Old 10-25-2013, 08:48 AM   #5
KTS
KTS's Avatar
Drives: Vitz RS
Thank you for the suggestions.
I will look at acquiring an engine harness when I purchase an engine and wire the AEM EMS-4 to the replacement harness in order to keep the original harness as original as possible.
Old 12-09-2013, 05:00 PM   #6
KTS
KTS's Avatar
Drives: Vitz RS
I acquired an auto harness and was wondering if there will be anything in particular I need to be aware of if I am going to use the auto harness on a manual vehicle for the AEM EMS-4 install.
I am planning to start the wiring/install in the next few days or as soon as I know for sure what to expect. Will post the diy once completed
Thanks in advance.
Old 12-09-2013, 05:46 PM   #7
Thanks in advance.
It's no problem using an auto one on a manual. There will be about a dozen wires that are not used, but it won't hurt anything to have them in place.
Old 12-09-2013, 08:32 PM   #8
KTS
KTS's Avatar
Drives: Vitz RS
Thank you CTScott you know this car inside out. That's exactly what I thought having additional wires that wouldn't be of any use but u confirmed it. Thank you again.
Once d AEM EMS-4 is installed and tuned N/A it will be time to install d engine I just bought and start the turbo vitz project.
Old 06-25-2014, 06:32 PM   #9
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
What engine is that?
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 01-09-2014, 10:55 AM   #10
Boost junkies
Drives: Toyota Vitz RS
Good luck with the build keep us posted ��
Boost junkies is offline   Reply With Quote
Old 06-25-2014, 09:53 PM   #11
KTS
KTS's Avatar
Drives: Vitz RS
I bought a used 1nzfe and installed it in the vitz in early January.
I did this as I didn't want to cause any accidental damage to the original engine for the car.
I already wired the ems-4 onto the auto harness but haven't installed it in the car. hopefully in the next few weeks I will install the ems-4 and the 1zz tb.
The main keep back is that I like the car and its original power output so I am not to inclined to mess with it, I never thought I would haved liked this car as much as I do....my previous car as a 200+whp Toyota EP82 Starlet GT
Old 06-25-2014, 10:02 PM   #12
KTS
KTS's Avatar
Drives: Vitz RS
my previous car.....I miss her at times
Old 06-26-2014, 10:51 AM   #13
Ryze268
Ryze268's Avatar
EP82s are nice, light-weight and very fast however they're too common down here. I bought a Vitz because its different.
How much did the engine set you back in Trinidad?
Old 06-26-2014, 11:03 AM   #14
KTS
KTS's Avatar
Drives: Vitz RS
About $3500 to $4000 TTD. Cannot remember the exact amount.
Sent from my ICONIA W510 using Tapatalk
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 10:40 AM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 02:50 AM
wtb extension harness Scubaru Steve Willing to Buy by private party 0 01-04-2011 09:56 PM
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 10:56 AM
