Old 10-19-2014, 10:18 AM   #1
Kar98
Drives: 2011 Scion tC
This right there is why ppl hate stealerships
Went to get my recall work (spiral cable, seat rails) done, and they gave my car a "multi point inspection."
This is what they said they've found wrong with it:
And this is how much they said they'd charge to fix it:
Oh no, that all sounds important, but I'm sure they had a good look and I can trust them, right?
Well lets have a look at the bits I can easily check and verify:
Filled washer fluid to proper level:
Bone-dry.
Adjusted tire pressure to 36 psi:
Serpentine belt cracked/damaged:
I'm half tempted to get a brake fluid spindle and check that too. As far as the "running rough" goes? Bullcrap. I had cars that run rough. I've had cars that were quieter inside, but those weren't Yarisses.
I'll accept that maybe the brake fluid, and MT fluid could be changed, and based on mileage, a new serpentine belt might not be a bad idea one of these days, but going by what they said is wrong with my car and the work they said they did, for all I know the recall work wasn't done either and all they did was run it through the car wash and sprayed some tire shine on the wheels.
When I get it done, I sure as hell won't have Toyota of Grapevine do it.
Kar98 is offline   Reply With Quote
Old 10-19-2014, 10:52 AM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Replace belt for $166 lmao I think that place is on crack ! That is just crazy !
I work at Toyota and sure we can be little more but nothing like ur estimate bill lol
sent from my S4 on Mars
Old 10-21-2014, 11:50 PM   #3
nookandcrannycar
. There is a fair amount of money in Southlake, Colleyville, and Grapevine. They probably have a fair amount of success pulling that c**p with the 'more money than sense crowd'.
Old 10-22-2014, 07:45 AM   #4
Kar98
Yeah but that crowd probably doesn't drive seven year old Yarisses, and did I mention that's still the newest car I've ever owned, even now that I've driven it for two years.
Old 10-22-2014, 04:35 PM   #5
nookandcrannycar
.....but could just be SOP for revenue generation......no matter what you drive....(but the 'conversion/say yes rate' would likely be lower for those with 7 year old Yarisses )
Old 10-19-2014, 11:29 AM   #6
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
You spelt Stealership wrong
Old 10-19-2014, 11:37 AM   #7
Kar98
Did I now?
Old 10-19-2014, 01:07 PM   #8
IllusionX
Drives: 07 Yaris Sedan Aero
It did not say the tire pressure was adjusted. It was a suggestion.
Anyways.. Your belt does show cracks. Look at the inside of the belt. And 100+$ for the belt and labour is about right to me.
Old 10-19-2014, 02:06 PM   #9
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Toyota belt is around 25$ install .2 charge so around 50$ plus tax u guys have crazy prices in the USA
Old 10-19-2014, 02:27 PM   #10
sheekeebut
Minimalist
Drives: 07 silver sedan
Please point these cracks out on the pics if you can. I see nothing wrong with it.
sheekeebut is offline   Reply With Quote
Old 10-19-2014, 02:50 PM   #11
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Crack will show on the inside of the belt from pic u can't see that tho u can see glazing .
Old 10-19-2014, 06:39 PM   #12
Kar98
It says they did, and the service adviser said they did.
$20 for the belt if I get an expensive one, loosening two bolts, swapping the belt, tightening two bolts while tensioning the belt with a crowbar, estimated time less than five minutes?
Just did the spark plugs myself, and WITH buying a ratchet and extension, and a 16 mm socket, I was still under $50 and it took less than five minutes.
Old 10-19-2014, 06:53 PM   #13
That's the sad reality of garage work now. Nothing is charged by actual time required. It's all 'job' cost.
Old 10-19-2014, 06:57 PM   #14
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
I so agree and the worse part is that most jobs are done in 1/3 of the time ,think main problem is flat rate .
If one needs a shop go to hourly place cos at least ur know its gone be done with out rush .
Old 10-21-2014, 12:13 AM   #15
phaznet
phaznet's Avatar
Drives: '07 Yaris Sdn
World Class Inspection, lol!
Maybe get it checked at a different Toyota dealership. I'm sure there's lots in the Dallas/ Fort Worth area.
Also, you can clean your throttle body easily, just purchase some throttle body cleaner spray. It would save you the 89$ + tax + labor.
phaznet is offline   Reply With Quote
Old 10-21-2014, 05:25 AM   #16
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Doing a check like that is not surprising, it is a chance for the dealerships to try and make money, after all the are businesses.
However I agree those prices are nuts. A good independent mechanic would do it for half that.
Colin Chapman disciple
Old 10-22-2014, 06:47 AM   #17
MoneyT8
Drives: White Yaris Sedan
Besides the usual rudeness like being hung up on and such the dealership I go to hasn't tried to upsell yet at least. I never let my guard down when at dealerhships in fact it's heighted. I will assume they're lying everytime they open their mouths.
MoneyT8 is offline   Reply With Quote
Old 10-22-2014, 08:28 AM   #18
IllusionX
I don't know how i would live in the states. Dealers are so far from each other they easily take advantages of people.
I hate birds!!!! Buckethead DIY / Maintenance / Service 19 03-17-2012 10:06 PM
Anyone Else Hate The Yaris Steering Wheel? PhilD424 Cosmetic Modifications (Exterior/Interior) 55 01-24-2011 07:08 AM
Have I mentioned how much I hate Speed sensors? staticorex General Yaris / Vitz Discussion 13 05-28-2009 04:04 PM
How many ppl are rocking stock shocks? Riced-yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 31 05-05-2009 02:08 PM
Hate for Yaris? redyaris General Yaris / Vitz Discussion 35 03-01-2007 07:58 PM
