Old 11-04-2008, 09:34 PM   #1
chriscruz2006
Drives: yaris 4dr sedan red
Instrument cluster light
Hi I just installed 17inch rims to my yaris and after I installed them, a error message light up in the instrument cluster, the tire pressure check light went on. I wanna know if somebody else have the same problem? Help please
chriscruz2006 is offline   Reply With Quote
Old 11-04-2008, 10:01 PM   #2
Did you move the tire pressure sensors from the old rims to the new ones?
Old 11-04-2008, 11:24 PM   #3
chriscruz2006
where is that located?
Old 11-05-2008, 06:07 AM   #4
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
the sensors are incorporated with your valve stem. I had this same problem when I put my rims on
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 11-05-2008, 08:30 PM   #5
chriscruz2006
do you mean i have to remove the tires of the rims, and remove the valve stems, and installed them to the aftermarket rims
Old 11-05-2008, 09:31 PM   #6
b_hickman11
Drives: 08 Sedan
Yes or buy new sensors and have them placed on your new rims. If you had this service done at a tire shop, by law they are suppose to do this for you(if your Yaris was made after Sept 2007).
b_hickman11 is offline   Reply With Quote
Old 11-06-2008, 02:50 AM   #7
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
wow theres a law about this hmmm
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 11-06-2008, 12:16 PM   #8
b_hickman11
Drives: 08 Sedan
Yes thats why all 2008's have TPMS on them, no matter what the make is. Also thats why a lot of tire shops are starting to charge more if your car is an 08 or 09(at least in my area.)
Old 12-12-2008, 12:24 PM   #9
Pitt Yaris
Drives: Flint Mica Sedan
i have stock everything, and my light came on about 2-4 weeks after i bought it *new* i checked the tire pressure, and it's fine. anything else i can do? could take it to the dealer, but would rather not deal with the hassle.
Old 12-12-2008, 02:50 PM   #10
You can read the error code from the "blinks" of the TPWS light. This will tell you what the TPWS thinks is wrong.
To do so:
1. Turn the iginition off
2. Connect the CG (pin 4) and TC (pin 13) pins together on the DLC3 connector (also known as the OBDII connector). You can do so with a small clip lead.
3. Turn the ignition on
4. TPWS light will light steady for three seconds
5. TPWS light will flash in a pattern indicating the stored DTCs (trouble codes). The pattern will require you to count the flashes and discern the delays between.
For example, if DTCs 13 and 23 are stored you will see:
0.5 second flash
1.5 seconds off (1)
0.5 second flash
0.5 second flash
0.5 second flash (3)
2.5 seconds off (gap between stored codes)
0.5 second flash
0.5 second flash (2)
1.5 seconds off
0.5 second flash
0.5 second flash
4.5 seconds off (gap between repeating)
Then, it will start again and will repeat until you kill the iginition and remove the jumper.
What the codes mean:
11, 12, 13 or 14 (Tire pressure low on one of the 4 tires)
21, 22 ,23 or 24 (No signal from one of the 4 sensors)
41, 42, 43, or 44 (Transmitter ID error on one of the 4 sensors)
65, 66 ,67, or 68 (Abnormal temperature inside one of the 4 tires)
71 (Transmitter ID not registered)
73 (Vehicle speed or Engine Speed Signal Malfunction)
76 (Malfunction in TPWS ECU internal cuircuit)
91 (Vehicle Speed Sensor Error)
94 (Engine Speed Sensor Error)
Old 08-25-2014, 12:18 PM   #11
robkay
Drives: Hatch
To do so:
0.5 second flash
1.5 seconds off (1)
0.5 second flash
0.5 second flash
0.5 second flash
1.5 seconds off
0.5 second flash
0.5 second flash
Hi, Is there a master list posted anywhere that has all of the codes?
robkay is offline   Reply With Quote
Old 08-25-2014, 12:44 PM   #12
That list is all of the codes. Because the Yaris does not register tires to specific corners, the 4 codes that all mean the same thing are due to the fact that it can be any one of the 4.
Old 08-25-2014, 12:51 PM   #13
robkay
Drives: Hatch
Oh, I don't mean just for tires, I mean everything. Or is there something to xref codes read via a jumper to the P type codes?
I jumpered my connector and I "think" it is giving me 34 and 39 (which may be meaningless because I initially had the jumper position reversed which reported nothing but a continuously flashing ABS light. THX!
Old 12-12-2008, 12:35 PM   #14
ddongbap
No.. really? I just thought it was only required by law to have the TPMS on the car from the factory.
Anything after isn't worth diddly.
Old 12-12-2008, 10:48 PM   #15
b_hickman11
Drives: 08 Sedan
Tire shops are required to make sure if they work on an 08 or 09 that they reset the TPMS or they could loose their certifications....but some smaller shops really dont get a damn.
Old 12-13-2008, 01:26 AM   #16
ddongbap
INNNNNNNNNNNNNNNNNTRESTING............
Old 08-25-2014, 01:18 PM   #17
robkay
Drives: Hatch
I've searched some. Guess I'll need to keep searching. THX
Old 08-25-2014, 02:00 PM   #18
If you can't find the threads on here. The codes are listed in the appropriate sections of the service manual (downloadable from the Micro Image forum):
http://www.microimageonline.com/foru...32-YARIS-FILES
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
2007 yaris instrument cluster rslyk Willing to Buy by private party 6 11-07-2008 01:41 PM
Instrument Cluster Stoln General Yaris / Vitz Discussion 2 06-23-2007 01:43 AM
instrument cluster swap S -> LB elo79 Performance Modifications 1 12-21-2006 10:22 AM
