Old 12-01-2021, 12:07 PM   #1
levanarosGR
Drives: yaris ts 2005
Exclamation Arp head studs help!
Hello guys, this is George from Greece.
I need your help with the typical arp nuts problem.
I read a topic here about the nuts that needs to be narrowed and the vvti valve.
I've already done the nuts so the cams are not touching, but my problem now is how to notch the vvti valve without damaging it to avoid touching the arp on first cylinder side on the intake camshaft.
I know I can mix arps with one OEM bolt at that point to avoid notching the solenoid but first I don't want to remove an arp stud for an oem one due to torque specs of each bolt, and second my motor is ready and I'm trying to avoid tearing down again to replace one OEM bolt!
Any help would be appreciated!
Thanks in advance.
levanarosGR is offline   Reply With Quote
Old 12-11-2021, 05:04 PM   #2
lani100
lani100's Avatar
Drives: Yaris T sport TRD turbo
I've read somewhere to use Toyota Prius C / Aqua VVTi solenoid as it's shorter.
2004 Yaris T-Sport
1NZ-FE with TRD Turbo
lani100 is offline   Reply With Quote
Tags
1nzfe, arp head studs, forged, turbo
Retorque ARP head studs turbo build nomad Forced Induction Forum 5 11-30-2021 03:57 AM
ARP Wheel Studs ArmstrongRacing Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 12-15-2018 11:08 PM
Head Studs sleey0 Forced Induction Forum 21 10-09-2010 05:31 PM
