Old 09-09-2014, 09:40 AM   #1
07stlYaris
If Its Not Blown It Sucks
07stlYaris's Avatar
Drives: 07 Yaris LB Meteorite
Fan Issues
When I first turn my A/C on the fan runs at the setting I set it at (typically 4) but it quickly slows down to what position 1 or 2 would output. Any guesses as to what's up? Is the fan speed analog or is there a speed controller somewhere?
07stlYaris is offline   Reply With Quote
Old 09-09-2014, 10:19 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
The cabin fan speed is adjusted with a resistor.
What happens if you run it without AC? Probably unrelated, but just what if.
If the resistor failed, it would not work, so my guess is your fan is defect.
Old 09-09-2014, 10:25 AM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Agree, your fan is suspect. Full speed should have "no" resistance from the control (I think) so any reduction of speed points to a bad motor. If it makes lots of noise, it's a bearing. If not, it's probably the brushes or a coil about to short out.
Old 09-09-2014, 11:15 AM   #4
^Exactly. I have a good OEM one on hand if you are interested. The fan motor is very easy to replace and access (just below the glove box) - Just disconnect the connector from the bottom of it and remove the three mounting screws.
Old 09-10-2014, 10:10 PM   #5
07stlYaris
07stlYaris's Avatar
Sorry for the delay. the fan housing has a bunch of water in it so ill be sorting that out first. my guess is the fan is going to fail due to the water issue. Ill let you know Scott.
Old 09-10-2014, 10:38 PM   #6
Sounds like the condensate drain is clogged. Do you have a cabin filter installed?
Anyone try a Ducted fan? UberSilver Forced Induction Forum 5 06-07-2013 11:57 PM
Fan Not Spinning Up, Random Airbag Light drannonb DIY / Maintenance / Service 12 10-23-2012 03:33 PM
AC Blower Motor / Fan Does Not Turn on Period dyslexicanaboko DIY / Maintenance / Service 7 01-30-2012 10:59 PM
Radiator Fan Rattle? Betrivent DIY / Maintenance / Service 9 06-23-2011 03:56 AM
