![]() Drives: Yaris Hatchback 2010 Join Date: Sep 2014
K & N Intake Trouble
Hello everyone, I recently installed a typhoon k & n intake on my Toyota Yaris hatchback 2010. The engine works fine but sometimes and repeatedly when I am in a stop the engine starts vibrating very rough until it reaches q peak and stops vibrating, it vibrates the whole car. I have tried tightening all the hoses but that doesn't seem to fix the problem. Any ideas on what it might be? Thank you in advanced.
Mr J.
Might have the IAT sensor slightly misaligned on the intake tube?
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Check the maf make sure its properly seated and clean too
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
How recent was recently?
If you had the battery disconnected while installing the intake, then the ECU is in learn mode and the car will idle very rough, nearly stalling out, until the air/fuel mixture is reset. This process takes some time.
![]() ![]() ![]() Drives: 2003 Mach 1 Join Date: Oct 2008
Yeah mine did that too - you have to disconnect the battery's negative terminal. It should run perfect after that;)
![]() ![]() Drives: 2010 3dr yaris Join Date: Jan 2013
Mine does something similar every since I got the car. The rpms fall to around 500 and will kick back up to 800 and idle there. At some point at the traffic light it may fall to 500 rpm again and do the same thing. It has never caused problems just something I notice from time to time. I have a 2010 manual and a cone KN filter.
Thanks guys, the problem has ceased to exist. It was the ECU was just adapting. Thanks.
#8 | |
Drives: Toyota yaris 2012 Join Date: Oct 2014
K&N intake fittment
i want to know if K&N 69-8612TFK will be fit in my new toyota yaris RS 2012 1nzfe engine? |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 06:34 AM |
| tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 09:11 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| The great intake debate! | fmicle | General Yaris / Vitz Discussion | 74 | 10-07-2009 12:37 AM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 11:07 PM |
