Old 10-20-2014, 12:05 PM   #1
supersonicsixteen
Drives: 2012 Toyota Yaris LE
Question Fan Knob Problem
So I'm having a problem with my 2012 Yaris LE. My fan speed is stuck on 4. My air conditioner and heating, and defrosting work just fine. The knob itself still clicks along fine, however it remains stuck on max blowing power.
I'm not sure at this point if the problem is electrical, mechanical or what. For now because of the noise I unplugged the back of that knob.
That's all the info that I know, any help would be greatly appreciated!
supersonicsixteen is offline   Reply With Quote
Old 10-20-2014, 12:25 PM   #2
jcboy
Drives: Sedan 07
i would assume the circuit inside the switch is shorted somehow--i think mechanically since 0 (turn off) still works. and since blowers 1, 2 and 3 are resistor-filled circuits, as compared to 4 which is a direct connection with the ground. and that's because the blower resistor is separate from the switch mechanism, which is where the power should run through when in 1, 2 and 3. hope it makes sense.
this is just at the top of my head, im no guru by any chance.
Old 10-20-2014, 12:29 PM   #3
supersonicsixteen
So the 0 setting doesn't work. 0,1,2,3,4 all act like 4 when it's plugged in.
Old 10-20-2014, 12:29 PM   #4
To find out where the problem is you can bypass the switch:
Jump the grey and white/black wires together and the fan should come on at the lowest setting.
Jump those two together and also Light blue for speed 2.
Jump those two together and also green for speed 3.
Jump those two together and also violet for high.
Old 10-20-2014, 12:34 PM   #5
supersonicsixteen
Sorry is jumping the wires when you put them together?
Old 10-20-2014, 01:08 PM   #6
supersonicsixteen
Thanks for the help CTScott!
Old 10-20-2014, 01:48 PM   #7
Yes. You could insert some small pieces of wire into the terminals for those wires and then touch the other ends together to "jump" or "short" them together.
Tags
fan, fan switch, fix, knob
front fan knob broken? pls help Mikastef DIY / Maintenance / Service 6 06-15-2014 04:34 AM
Shift Knob Threaded Insert Install DIY Yariz_Hatch DIY / Maintenance / Service 1 02-09-2012 09:15 PM
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 02:30 AM
Problem Starting Car drunkwithwords General Yaris / Vitz Discussion 3 07-21-2010 05:01 PM
Yaris Central Locking Problem pbasuita UK 0 07-10-2010 04:46 AM
