Old 05-14-2009, 05:38 AM   #1
window_lee
Drives: Yaris RS 2007
PCV valve question
Do we need to replace PCV value???
if we do, when??????
window_lee is offline   Reply With Quote
Old 05-14-2009, 08:45 AM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Every once in a while its a good idea to clean it or replace it,its just a ball bearing/rod in a tube that prevents the ventilation of crankcase fumes going back in the crankcase.Every 50k should do it.
http://media.photobucket.com/image/p...v_function.gif
Old 05-14-2009, 05:10 PM   #3
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
funny this thread popped up, i went the the dealer an hour ago to ask the same question. they said at the time you change the spark plugs..which they said was 100k... i call bs on that time frame.
mikenacarato is offline   Reply With Quote
Old 07-07-2009, 09:12 AM   #4
SweetRS
Drives: 2006 Yaris Rs
Iridium plugs only need to be changed every 100k....
SweetRS is offline   Reply With Quote
Old 07-07-2009, 03:19 PM   #5
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Yep. RTFM.
Old 07-07-2009, 06:25 PM   #6
mikenacarato
SIPNDEW
Drives: 15 STI
i wasnt referring to the spark plug change interval being bs...i was referring to the pcv valve being replaced at 100k, i believe it needs to be more like 50k
Old 05-14-2009, 05:12 PM   #7
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
50k miles? how expensive is it and can I do it myself? im a bit over that.
Old 05-14-2009, 05:14 PM   #8
mikenacarato
SIPNDEW
Drives: 15 STI
under $10 and if you follow the vacuum line from the manifold to the side of the valve cover (the back line) then you found the pcv valve.
Old 05-14-2009, 05:17 PM   #9
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
i purchased a replacement PCV valve and it leaked worse than the OE one. i'd say it does NOT need replacing. it's a steel check valve, not plastic, there's no parts to wear out.
Originally Posted by xnamerxx
you nailed it sir.
Old 05-14-2009, 05:18 PM   #10
mikenacarato
SIPNDEW
Drives: 15 STI
it gets gunked up with blowby oil and will stick the valve up and possibly blow other seals (the vacuum has to come from somewhere else if the tube is blocked up)....it does need replacing...ESPECIALLY for you tamago as you pull more vacuum than normal.
Old 05-14-2009, 05:20 PM   #11
Tamago
Tamago's Avatar
Drives: ZZW30
it's a metal ball in a metal casing.
if it gets gunked up, spray some brake parts cleaner in it and some compressed air, re-install.
if it was plastic i'd agree with you that it should be replaced, but it's not.
you nailed it sir.
Old 05-14-2009, 05:22 PM   #12
mikenacarato
SIPNDEW
Drives: 15 STI
its called preventive maintanence for a reason. also, as hot air gets taken into the valve or just the valve heating up in general will wear that spring out and make it brittle and break, which is also another cause of a stuck pcv valve. a good way to check it is to remove the valve, shake it, if the ball clicks, put it back in.
Old 05-14-2009, 05:26 PM   #13
Tamago
Tamago's Avatar
Drives: ZZW30
160F air will make metal brittle?
i'm not saying it should NEVER be replaced, but it's definitely not a feeble piece of plastic like most cars (domestic especially).
you nailed it sir.
Old 05-14-2009, 05:28 PM   #14
mikenacarato
SIPNDEW
Drives: 15 STI
do what you will but a few bucks every now and then wont hurt to protect your investment.
Old 05-14-2009, 05:35 PM   #15
Tamago
Tamago's Avatar
Drives: ZZW30
i'm getting ready to be on engine number 3.
PCV's are the least of my concern :D
but thank you for yours!
you nailed it sir.
Old 05-14-2009, 05:36 PM   #16
mikenacarato
SIPNDEW
Drives: 15 STI
eh anytime ;)
when i upped the turbo on my last car i had a sticking pcv valve causing the car not to run 3-4 times. but i was running 25 psi
Old 05-14-2009, 05:51 PM   #17
Lafiro
Drives: 06 Yaris Sedan
Can there be a DIY on how to find this, how to remove it, what to use to clean it, and how to reinstall please.
I just hit a little over 50k miles, and I will be replacing shocks/drum shoes/spark plugs soon.
Thanks.
Old 05-14-2009, 05:54 PM   #18
Tamago
Tamago's Avatar
Drives: ZZW30
Thanks.
you'll need a left handed metric adjustable wrench and a 10mm socket to remove your plastic engine cover.
the drivers side of the engine, on the cam cover closest to the engine, you'll see a hose coming out and going to the intake area. use the metric left handed adjustable wrench to remove the pcv.
if you choose to clean it, use carb cleaner and a short blast of air to ensure there is no gunk inside.
if you choose to replace it, buy a toyota part. the aftermarket ones are junk.
you nailed it sir.
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 03:39 PM
Transmission Question CMR General Yaris / Vitz Discussion 42 04-14-2010 01:38 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 04:59 PM
dealer trade-in payoff question.. kapo New YARIS Purchase Forum 1 07-16-2007 11:27 PM
2007 Yaris LB - Valve Adjustments Pavel Olavich DIY / Maintenance / Service 3 03-30-2007 06:34 PM
