![]() Drives: 2013 Yaris Join Date: Nov 2013
Engine rev limiter override
Hello:
I have a 2013 Yaris with a manual transmission. California emissions. Does anyone have any experience in attempting or successfully bypassing the rev limiter on this vehicle? |
The Yaris ECM has a hard coded rev limit. To bypass it requires running a stand-alone ECM.
![]() ![]() Drives: 2007 yaris HB Join Date: May 2013
In some older yotas you could change out the crystal on the ecu. However I am fairly certain any attempt at a similar mod on these ECUs would be difficult and if possible probably mess something else up too since I always thought it chanfe the clock speed of the ECU... might not be the right term.
| Toyota's new subcompact will use Mazda's Skyactiv engine | Kal-El | Off-topic / Other Cars / Everything else Discussions | 43 | 03-25-2014 01:01 AM |
| 1kr-fe engine wiring | boothybunch | DIY / Maintenance / Service | 0 | 03-28-2011 03:59 AM |
| Engine noise and Oil Lamp on | bieniman | DIY / Maintenance / Service | 21 | 12-12-2010 11:47 PM |
| rev limiter | mastaofdisasta | Performance Modifications | 2 | 11-24-2008 03:10 PM |
