![]() ![]() ![]() Drives: 2002 JDM Vitz 1.3 Join Date: Feb 2013
As the title asks, I just wanted to know if you guys were stuck withan automatic 2NZ-FE 3 Door Vitz what would you do?
Rules: Selling it is out of the Question Engine Swap is out as it is too costly Goal: At least 120 ps Budget $1000 USD Yes, I am secretly asking this to explore my own tuning options
play every day
ThatYarisGuy
Drives: Toyota Yaris 2012 SE Join Date: Oct 2012
short ram intake - $80~$180
cold air intake - $150~$250 racing headers - $150~$260 axle-back exhaust - $280~$360 cat-back exhaust - $450~$550 Garm's intake manifold ~ $700 lol this is probably a +10 -15 ish hp gain with headers intake and exhaust and intake manifold.
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
it is a 2NZ-FE so i'm not really sure that the intake manifold will even bolt on.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#5 | |
play every day
Looking at the 2NZ FE specs showed that it's the same bore as a 1NZ with only a shorter stroke. Under the hood clearance of other components is an unknown, but could easily be determined with some careful measurements. Even that exhaust header pictured above is listed as fitting both 1.3 and 1.5 engines. |
I'm glad I came to this site, you guys are legit =D
I have been looking around but I can't seem to find any headers, it also sounds like I should visit my local fab shop as decats are legal where I live |
Save up for a supercharger.
![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
Leave it as is. It's meant to be a granny mobile. Nah.. Seems to me the common mods are ; 1zz throttle body, spacer and garms intake manifold.
![]() ![]() ![]() Drives: Yaris Hatchieback Join Date: Jun 2010
Upgrade your suspension and smoke fast vehicle in to the turns. They brake in the turn and your gas exit the turn.
Yes, definitely won't ignore the suspension and I don't see my Vitz as a 'granny mobile' =P
Would it be possible to stroke the 2nz to a 1.5? If possible how would I go about doing it?
Just get 1nzfe crank/listless/rods
But just get coilovers and tires...
Pistons...auto correct
^ It's that easy? If yes I'm definitely going to do it =D
Doesn't the NCP10 use xA/xB peripherals, like cable throttle?
![]() Drives: Yaris Sedan YRS Join Date: Mar 2013
| Need Help with 2NZ ECU pinout | Aleil | DIY / Maintenance / Service | 3 | 12-28-2020 10:40 AM |
| Using DFCO to increase your MPG | BailOut | Fuel Economy Forum | 216 | 08-30-2018 05:15 AM |
| Turbo for 2NZ.... | Centurion2200 | Forced Induction Forum | 9 | 08-25-2007 07:14 AM |
