Old 11-15-2014, 04:54 PM   #1
NEexpat
Drives: 2009, auto, 4dr LB
Just something I do........................
I run dedicated snow tires on steel wheels they go on at the last possible moment before an appreciable snow storm and they come off when I feel confident that is it for the winter. Then they sit in the garage till next season. As do my 3 season tires when my snows are on.
Well I like to know which wheel came off where so I mark the inside of my wheels with phosphorescent pink nail polish I got at the dollar store.
Starting at 1 o'clock going clockwise I dot the wheels.
Right front - 1 small dot
Right rear - 2 small dots
Left rear - 3 small dots
Left front - blank
I do this to both sets so I know how to rotate them back and forth season to season. I have a clip board in the garage that tells me things, such as how many hours are on the snow blower, lawn mower oils etc. as well as are the Yaris tires going back to front or front to back.
I used to do this with chalk until I hosed off all the dust on the tires with the garden hose one spring.
NEexpat is offline   Reply With Quote
Old 11-15-2014, 05:29 PM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
okay, that is a bit extreme, but if you like it, go for it.
Colin Chapman disciple
Old 11-15-2014, 05:49 PM   #3
NEexpat
^Ya think, I wash em down before they go in the garage and treat any rust spots on the wheels with Extend rust neutralizer.
Old 11-15-2014, 05:57 PM   #4
I use a grease pencil and write on the inside sidewall the corner the wheel came from.
LF RF
LR RR
To me seems easier than a system of dots.
Old 11-16-2014, 01:35 AM   #5
fourbangingfun
fourbangingfun's Avatar
LF RF
LR RR
+1 same here
fourbangingfun is offline   Reply With Quote
Old 11-15-2014, 06:15 PM   #6
NEexpat
^That's pretty much what I did with the chalk. I just wanted something brighter and a little more permanent.
Old 11-16-2014, 03:00 AM   #7
john21031
Drives: '10 Fit Sport MT and 2012 Fit
I thought your title will explain what you do to afford a garage in New England.
john21031 is offline   Reply With Quote
Old 11-16-2014, 08:06 AM   #8
IllusionX
Drives: 07 Yaris Sedan Aero
Snows go on when temps are below 7c in the morning when I go to work.
And i only buy unidirectional tires.. So I always stack my tires front/rear. Rear in the bottom. So I know that I have to put the top at the rear in spring.
Old 11-16-2014, 12:23 PM   #9
fourbangingfun
This is going to be my first winter with directional snow tires (Blizzak ws 70s). How often do you rotate front to back? Just once every winter?
I'm a little bit concerned with tire wear because of how you can't switch them left to right. I'm recently lowered on Tein S springs, and I had a legitimate alignment done (went into the shop and got to watch the tech do it), but I'm still a bit apprehensive in regards to my front tires getting some uneven wear.
Old 11-16-2014, 01:42 PM   #10
IllusionX
As long as you don't have any toe, you should be pretty good with wearing. My rears are wearing a bit on the inside. I am unsure if that is caused by the camber I have on the rear or maybe there is some toe.
I only rotate front/back after the season since I don't drive that much. Even if you drive average mileage (20k km) a year, then you don't need to rotate mid-season.
Old 11-19-2014, 11:58 AM   #11
why?
why?'s Avatar
Drives: Yaris LB
At most you really only need to rotate tires 5,000 miles. Many people can easily get away with a ton less.
