![]() ![]() Drives: 2010 Blazing Blue 3 Door LB Join Date: Dec 2013
Foggy windows
My windows always fog up real fast unless I keep the knob at front defrost setting. Why? Also i think I may have the stink air vent issue that I was reading about on here. Could those 2 be related?
15' - Crosstrek Hybrid ~ Plasma 10' - Yaris 3 Dr LB ~ The Boom Box 06' - RSX Type S ~ H.S. Dream Car 95' - Delsol VTEC ~ The Racecar 12' - Burgman 400 ~ Garage Queen 09' - Agility 125 ~ 80mpg Daily Rider 09' - Metropolitan ~ Weee 14' - Ecosmart Metro ~ Razor |
#2 | |
USAF_SrA_E-4
My sedan still have that problem it doesn't bother me so much, as to the fogging idk I'd gotta ask the wife if she has that problem.
Off topic : got some pictures of that del sol? I got a black 97 si
If they fog up quickly when not in defog mode then there is moisture in the air inside of the car. That moisture can come from your breath, from condensate in the bottom of the airbox or from moisture in the carpet. I find that if I am driving alone I get far less fogging than if my wife and daughters are in the car as well.
![]() ![]() ![]() Drives: No more Yaris Join Date: Dec 2013
If the air is moist, and it's much colder outside than in, the windows will fog up.
There's only two ways to deal with that: Blast hot air on the glass; or dry the air inside the car. Hot air, is the defroster set on high heat. Takes cold air outside...as air is heated, its capacity for moisture increases; and if no water is added it becomes much drier. So even if it's 80 percent humidity outside at 0 F, once it's warmed up to 90F or so, it'll be very dry. Blasted on the glass, it will dry it off. The other way, is to turn the heat down - and put the Air Conditioning ON. Yup...Air Conditioning dries the air. You're in your car on a snowy day...your shoes and pants are wet with snow; there's puddles in the footwells. That moisture circulates. Air Conditioning dries the air to where it will help remove the window steam without melting your face. Third option, of course, is to just open a window. Not a big deal at 30F; killer when it's ten below. |
Defrost setting is kicking in the A/C compressor. That is why all the F/E fanatics go to great lengths to avoid using defrost.
#6 | |
But you're right, it does generally go on. I don't like it for just that reason, fuel economy; but truth is it DOES help a LOT with window fogging. Older Chryslers used to turn off the A/C compressor if you pulled out the DEFROST button after pressing it in, on those pushbutton heater controls they had. Worked that way even after they removed the tang that let you easily pull the button back. In that little way, Chrysler was ahead of Toyota... |
Ok, so you guys are telling me im getting almost 50mpgs on winter blend with my ac on blasting hot air? The interior space on my delsol is probably half of what the yaris has and it never fogs up like the yaris does.
![]() Drives: 2007 Yaris Join Date: Sep 2011
I had a severe window fogging/icing problem on an 07 sedan and it was making me nuts. I checked everything that could possibly be causing it such as wet floor or seats, leaking windshield, clogged drain from evap case, or leaking heater core. All checked out ok.
The solution was so simple it's embarassing. The HVAC control was set to "recirculate". Switched it back to fresh air and it's all good now. |
#9 | |
![]() ![]() ![]() You saved my life.
#10 | |
I personally don't like it - many times I've used the fresh-air cut-off when behind an out-of-tune diesel or near a squashed skunk. And I used to warm the interior of the car with the fresh air cut off, but the fan low and blowing on the glass. With no bodies inside, it did fine - and warmed up the interior faster. |
It looks like i'm not alone with this issue. But it doesn't bother me much, as it clears itself out once the engine is warm and blows hot air. Otherwise, defrost it goes or i turn on the AC.
This didn't happen with the Echo i had before. |
![]() ![]() Drives: 2002 Toyota Yaris T-sport Join Date: Jan 2014
I have the same with my yaris and have had the same with my old seat marbella (yeah, google it, and I dare you to laugh because those things are epic). Alongside the car's own systems I just put a moisture eater on the passenger seat, one of these things you usually put in the room with your wooden instruments or fancy clothes:
![]() I have to say it really helps :) Off course when the car is full it will still fog, but in general it keeps the inside of the windows moist free. The other thing that helps is cleaning your windows on the inside with some fat remover or glass cleaner. |
![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
A tiny leak in the heater core can cause your windows to easily fog and not be big enough to wet the floor or carpets.
| Installation of original power windows and locks in Yaris | lantis | DIY / Maintenance / Service | 4 | 02-25-2012 02:38 PM |
| Got my windows tinted......need advice now to get it redone | yarisitis | General Yaris / Vitz Discussion | 17 | 01-30-2011 01:52 PM |
| Tinting lights & windows pricing | wiirenet | Cosmetic Modifications (Exterior/Interior) | 15 | 03-22-2009 01:09 AM |
| Foggy WIndows | tank0r | General Yaris / Vitz Discussion | 12 | 12-24-2008 03:51 PM |
| Tinted Windows | casterqc | Cosmetic Modifications (Exterior/Interior) | 50 | 10-05-2006 04:45 AM |
