![]() ![]() Drives: Yaris HB Join Date: Dec 2014
Hello everyone!
Can someone help me telling me where are the vacuum hoses? Yesterday I installed a VAC Gauge, but I made the mistake of confusing the purge valve hose. I found this picture of another thread, but according read this hose goes to the brake pump. link: http://www.yarisworld.com/forums/showthread.php?t=39641
VELMAX member. |
someone?
VELMAX member. |
![]() ![]() Drives: 07 hatchback Join Date: May 2012
Look for the sensor attached to the intake tube. It has a hose running to it and out of it as well as an electrical connection. That should do you. You can also use the brake booster hose(might be the same hose) or the pcv hose but this will have some oil and moisture in it
#4 | |
Previously I had done after the sensor.
VELMAX member. |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 09:14 PM |
| HVAC dripping water when AC on. Drain hose is NOT clogged. | kustomrtr | DIY / Maintenance / Service | 3 | 09-07-2014 10:45 PM |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 06:34 AM |
| vacuum hose / heater hose size | cali yaris | Performance Modifications | 12 | 05-17-2013 10:58 PM |
| Where is are all the vacuum hoses sourced? | LtNoogie | Performance Modifications | 1 | 05-17-2009 05:22 PM |
