Old 01-20-2015, 11:23 PM   #1
Mark-UPI
Drives: Toyota Tacoma
Rear Drum to Disc Brake Conversion
Hey guys, my name is Mark, and I am trying to gauge to see how much interest there might be in a new Rear Drum to Disc Brake Conversion kit.
There is a new company that is offering a completely new kit that switches your rear drums to rear discs. The parking brake still utilizes the drum system though. I believe that this kit is all inclusive, meaning, that everything that is needed to do the conversion is all included in 1 package.
I was just trying to see if there was any interest in the Yaris world to begin with. If you guys have any questions, please post them here, and I'll definitely answer them to my best ability.
Thanks!
Mark-UPI is offline   Reply With Quote
Old 01-20-2015, 11:39 PM   #2
sheekeebut
Minimalist
Drives: 07 silver sedan
I considered the runstop ones at MI, but unless you have standard (based off an OEM part, preferably from fronts) pads and rotors that will fit them, I will reluctantly stick with my drums.
sheekeebut is offline   Reply With Quote
Old 01-21-2015, 05:22 AM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Yea, what Sheekeebut said, Micro Image sell them. To be honest, I am reluctant to upgrade to that style because I want to get rid of the drums altogether. I am still searching for JDM rear disc from overseas because they utilize the caliper for the hand brake instead of a drum hidden behind the back.
-Derrick-
Old 01-21-2015, 08:43 AM   #4
Kar98
Drives: 2011 Scion tC
If you need somebody locally to get it done for free and then heap praise about your company in all the forums...
Old 01-21-2015, 10:26 AM   #5
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Intrested it has to look OEM and the rear disc doesn't look pretty being way larger than the front... Must accept 15"
You should look in to non drum setups scion XB uses tokico calibers with non drum ebrakes...
Also look in to selling half kits $800 dollar kits fail against a 100 find it yourself type youll have less stock and will sell more brackets even to people that don't even end up finishing the kit... I've seen this in the Suzuki Samurai forums people prefer spending more money getting the parts little by little than dropping less money on a single purchase.
But thats my opinion
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 01-21-2015, 12:38 PM   #6
ilikerice
ilikerice's Avatar
This is true. I can hide explain several $100 purchases over 8 months rather than 1 large purchase for $800 to my wife.
-Derrick-
Old 01-21-2015, 06:35 PM   #7
Mark-UPI
Thanks for all the great feedback. I'll definitely take this back and let the company know what people are asking for.
Keep it coming!
Old 01-21-2015, 10:13 PM   #8
enviri
enviri's Avatar
Drives: 2010 Yaris
the biggest thing that's different with the drum equipped yaris beam and the one equipped with rear disc is taht the mounting plate for the hub also has accommodations to mount a rear caliper. it gets rid of the drum completely. hubs are identical. fab a caliper adapter plate, disc backing plate, and get some calipers and rear discs from oem 2012+ se. if you wanna go lightweight you can fab taht too.
the ebrake cable can be made or use oem yaris SE cables. the stock diameter for rear discs is 260mm. It might look funny with the front 255mm yaris base models tho :P
Old 01-22-2015, 03:33 AM   #9
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
the rear disc axle rotor looks so tiny. But im on 17in rims. I know a bigger rotor doesnt really do anything and its the bigger caliper and pads that matter... Ill wait till i need brake pad change. Enviri, do you have bigger rotors?
Check out my Build thread:
Old 01-22-2015, 11:30 PM   #10
enviri
enviri's Avatar
Drives: 2010 Yaris
no i dont. i use 16s like a sensible person lololol...unless you're talking about the fronts, then, yes i am using bigger 275mm rotors on matrix/corolla/XD calipers. direct bolt.
Old 01-23-2015, 12:38 AM   #11
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Enviri you can't use 15" rims with the front rotors??? What dics did you use?
R-CaT
Project Yar 2ZR
Old 01-23-2015, 01:01 AM   #12
enviri
enviri's Avatar
Drives: 2010 Yaris
you can use 15" with the front rotors. i'm using them now for snow time. You use 2012+ Yaris SE rotors (43152-52130)
Old 01-23-2015, 01:10 AM   #13
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Great I got some light 15" wheels for the track and if I upgrade the brakes don't want to loose that... I got to rethink brakes I wasted a pair of pads in less than a year
R-CaT
Project Yar 2ZR
Old 01-23-2015, 09:15 AM   #14
nortonfb
Drives: 2007
Are you saying you can use a larger rotor without changing the stock caliber?
No mods?
Norton
nortonfb is offline   Reply With Quote
Old 01-23-2015, 09:36 AM   #15
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Nortonfb no you need corolla, matrix or XD caliper
R-CaT
Project Yar 2ZR
Old 01-23-2015, 12:15 PM   #16
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
I think that if they use XB2 calipers it would be more easy to source than a uncommonly Yaris SE....
R-CaT
Project Yar 2ZR
Old 01-23-2015, 01:14 PM   #17
enviri
enviri's Avatar
Drives: 2010 Yaris
yaris se calipers are actually physically smaller in size, and as far as i know, bespoke to the car, hence why i went to the corolla family and xd front calipers...more avail.
Old 01-23-2015, 01:21 PM   #18
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Just in case I was refering ti the rears
SE is not sold in PUERTO RICO.... But I got so lucky that they opened an advance auto a month ago and 1 set of each came in the new stock picked them up today fronts and rear since it not they wont stock up again you never know if I get to invent someting
R-CaT
Project Yar 2ZR
Drum brake problem. theb DIY / Maintenance / Service 4 04-23-2014 03:04 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 08:34 PM
rear brake drum leak Liu997 DIY / Maintenance / Service 6 06-26-2010 07:13 PM
Rear brake proportioning valve??? PetersRedYaris DIY / Maintenance / Service 16 03-26-2007 12:10 AM
