![]() Drives: Yaris Join Date: Dec 2010
Drive Belt replacement
My 2010 Yaris bought in Dec-2010 so practically a 2011 purchase.
Only has 30K miles, went to dealer for oil change (replacing Air filter myself). Dealer recommends drive belt change every 2 years and wanted to change on my car for $150 since it has been nearly 4 years. this is highly surprising that the belt would need to replaced so soon. any thoughts? or this is dealer just being a 'stealer'? |
2ZR swap. DO IT! Ask how!
Check the service interval in your owner's manual/maintenance guide for verification. If it's not showing symptoms of wear--cracking, fraying, excessive play--then I wouldn't worry about it.
HIGHLY unusual! You can check the belt yourself. #1 is it squealing during startup? If not thats good. Squealing indicated a loose belt.
#2 check the mult-ribed surface on the inner side of the belt. Without the engine running feel the inner side of the belt with your fingers. There are about 5 mini V's on it. As long as these are intact and not hanging in shreads or little bits missing from the tiny V's belt is good. If the dealer changes ANYTHING tell them you want the old parts! Good luck and tell us what happens!
#4 | |
#5 | |
I would say even a squealing belt as long as it drives the accessories is OK and isn't flapping loose. As long as the mini V's aren't damaged. An overtightened belt can damage the water pump and other driven accessories. ![]() My wifes 05 Camry with 120k on it has the original belt. I can see nothing wrong with it. I check the mini v's every oil change. (twice a year) When the mini v's get damaged....off to Toyota for a new one! My brother in law changed the wp a couple years ago and when he did he changed the belt tensioner it was bad. Yaris has no bt.
Why not just get a new belt and change it on ur own ...will run u maybe 15$ to 30$ for belt and 10 min job.
Did my belt at 110km |
Don't forget that rubber so dry up. So even if you did not drive much, it can be safe to check the belt for damages/dry rot and replace as necessary.
| yaris timing belt | phenoyz | General Yaris / Vitz Discussion | 16 | 02-24-2015 02:05 AM |
| drive belt | neal3d | DIY / Maintenance / Service | 0 | 06-07-2014 01:11 PM |
| seat belt chime disable? | Lewis | DIY / Maintenance / Service | 19 | 05-25-2012 05:36 PM |
| HELP!? HORRIBLE drive home during first REAL Snow in Michigan, | paulyd0021 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 12-11-2009 09:07 PM |
| HELP!? HORRIBLE drive home during first REAL Snow in Michigan | paulyd0021 | General Yaris / Vitz Discussion | 32 | 12-10-2009 02:23 PM |
