![]() ![]() Drives: 07 Yaris Join Date: Dec 2009
Exhaust bolt size?
I need to know what Thread/size bolt fits the axle back portion of our cars, I no longer have the spring bolts and need two bolts that fit! dumb question but hope someone can help!!
Get the spring bolts kit from Rockauto. They are like 6$ or so.
Are you looking to temporarily bolt together until you can get new spring bolts? If not, and what you are doing is permanent, forget it. The gasket will not function properly without spring bolts.
no looking to use regular bolts to attach my Dc Sport axle back it has no gasket, which is currently off the car. had the spring bolts but they were causing an awful rattle that was driving me mad, so I took everything off until I find a solution. The noise was from the bolts because when it would rattle I could put my hands over the spring bolts and it would stop.
#5 | |
Ahh okay! Thank you, Thats what I needed to know! Guess Ill order those ones from Rockauto.
Got the bolts from rock auto, and there not threaded all the way on the bolt, just the tip like the factory ones so we will see if these work if not I will need to get new 10m 1.25 bolts to use with these springs
Ah. They must have changed suppliers. I have two sets sitting here that are both the full threaded ones.
Make sure you get the stainless steel ones from Home Depot.
That's weird. I am shopping for new bolts kit and gaskets for mine, and according to RockAuto, they are fully threaded with a sleeve to cover part of it.
| Bolt Pattern Size and Offset for the Stock Wheels | fmicle | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 08-12-2009 04:35 PM |
| Size of exhaust hanger?? | AlainMikli | Performance Modifications | 3 | 07-05-2009 06:07 PM |
| head bolt socket. What size? | beemer dave | DIY / Maintenance / Service | 3 | 06-02-2009 05:15 PM |
| GReddy prototype = Free Exhaust! | Chris_Lum | California | 30 | 02-27-2007 11:13 PM |
| Fujitsubo Exhaust!! | MC-BPT | Sponsors Classifieds Area | 17 | 11-16-2006 11:36 AM |
