Ambient temperature sensor OBD-II data
I've read the Yaris has an ambient temperature sensor in the front bumper. Is there any way to access that information? I have a PLX Kiwi Wifi with DashCommand app, but it shows temperature is not a supported metric.
The sensor is for the duty cycle of the AC. Apparently,there is another one at the condenser, to prevent freezing.
#3 | |
Mr. 155 and climbing
Yup....doubt that you would be able to access that with anything but the TechStream from Toyota.
It can only be read by talking to the AC ECU, so normal OBDII PIDs for ambient temp don't work.
![]() ![]() ![]() Drives: 2005 Toyota Vitz RS Join Date: Jan 2012
You can only access that information with Techstream.
Embracing Curves
Drives: '14 Prius Executive Join Date: Aug 2013
Nope, If I remember correctly I had been able to read it out using Torque, the right header and the right PID.
I don't remember it exactly, but I took it from a PID set for a Prius of the 2nd gen I think.
I drive, therefore I am. |
We are talking about a yaris here. The Prius have an ambient temp sensor.
So does the Yaris. I display the ambient temperature on my YarGauge (homemade diagnostic tool), but you have to talk to the AC ECU to get the data, rather than to the ECM (so it is not a standard OBDII PID, but rather a manufacturer specific diagnostic PID).
#9 | |
Does that mean Toyota uses the same sensor, and get the info from the AC ECU in some cars? |
Yes. But, some (including the 2010+ Yaris) pass that data to the ECM, so that it can report it with a standard OBDII PID.
![]() ![]() Drives: 07 hatchback Join Date: May 2012
Ctscott is it possible to set this up on a Scangauge 2?
Possibly.
Ctscott please post the pid you used to get the info from the Ac ecu.
#14 |
2122 is the command, sent to address 07C4.
#15 |
![]() Drives: 09 Yaris Join Date: Mar 2015
Do you know if the '09 is different than a '10 in this respect? I just replaced my '10 with an '09 and I can't seem to get the Amb temp on my Scan Gauge II anymore???
#16 | |
As I said in post 12 above - The 2010 and newer Yaris supports it. No prior years do.
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| Debunking fuel conservation myths... | nmgolfer | Fuel Economy Forum | 144 | 10-28-2010 10:51 PM |
| Water temperature | Bob_VT | General Yaris / Vitz Discussion | 11 | 11-03-2008 04:17 PM |
| ambient map lighting? | atebit | Cosmetic Modifications (Exterior/Interior) | 0 | 11-05-2006 02:15 AM |
