Old 12-28-2010, 01:33 PM   #1
bankrobber
Drives: 2007 Yaris Hatchback
Replacing spark plugs
I am at 104,000 miles. Thought I would replace spark plugs with some good quality ones from AutoZone for about 8 dollars each. I believe OEM at dealer is 12 to 15 each. Anybody try AutoZone?
bankrobber is offline   Reply With Quote
Old 12-28-2010, 02:07 PM   #2
toad
toad's Avatar
Drives: street-legal go-kart
i would stick with the either the oem denso or ngk IRIDIUMS. i just changed mine out a month or so ago with about the same mileage.
there's plenty of debate as to whether or not the iridiums actually do anything better than other grades, but all i know is i won't be changing my plugs again for another 100k miles!
i didn't know autozone made their own iridiums, but for a few dollars more per plug i'd go with the name-brand ones for piece of mind(it may be the last plug change you do on this car).
toad is offline   Reply With Quote
Old 12-29-2010, 12:26 AM   #3
slow.yaris
Drives: 07 yaris sedan
1) I've had autozone parts last longer than name-brand OEM parts
2) Those longer lasting parts also came with warranties
3) Autozone sells NGK
4) Autozone FTMFW ;)
slow.yaris is offline   Reply With Quote
Old 12-29-2010, 04:32 PM   #4
severous01
agreed. i went through 20 sets of 'toyota' wipers....and kept doin the parts warranty thing...well they stopped the parts warranty. so i shopped around. michillin, annco, bosch, rainX, and all sorts of other brands of inserts and whole blades. always streaking on the first swipe and never lasted more than a month. bought a set from autozone, the 'duralals' wipers for 12 bux a set....works perfect and going on 6 months now.
also, as long as you're not getting the cheapo, bottom tier stuff like brake pads or rotors, you can expect better than stock performance out of them. i like mid-grade or better myself when it comes to pads, and top tier when it comes to rotors. as for plugs and wires....they're all basically the same. but i'll never use bosch, and i wouldnt put champion in my lawn mower. other than that...delco, ngk, auto-lite...whatever's better in your opinion.
a lot of times what happens is when a patent runs out everyon and their mother will mimic that patent and make just as high a quality part as the big guys. the parts use the same materials, the same processing, and in more cases than not...the same plant and distributors/packaging companies. do some research on your companies. if you're in the grocery store check the labels. market basket uses 'parade' brand and if you look on there it's packaged in the same plants as KRAFT, oscar myer, McKormick, Betty Crocker and all the other name brands...and that means the same product.
Old 12-29-2010, 05:20 PM   #5
jstantherprsn
Drives: 01 Toyota Echo
The first thing I did was swap out the spark plugs when I got the car. I had original oems and replaced them with the new iridium fusion (platnium) plugs. Need the iridium because without it, they get to hot. They run great, the idle is smoother, I haven't had any problems and I got 4k on them now. There was a sale a while back so you got 2 bucks off each plug. I'll check them later but I doubt there will be and problems.
jstantherprsn is offline   Reply With Quote
Old 12-28-2010, 02:16 PM   #6
bronsin
bronsin's Avatar
Why spend $$ on a car you may not own in the near future?
Old 12-28-2010, 03:14 PM   #7
johnny_vitz
Drives: 2005 Toyota Echo
^^ lol
If they are the same plugs as the older echo (i'm pretty sure) they are $4-$5 cdn (each)from the dealer for Denso. It's your best bet, there's really no need for iridiums which are at least double the price. The only realy advantage is extended service life. NGK is good too
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 12-28-2010, 04:39 PM   #8
bankrobber
I can get NGK iridums for 6.99 each at AutoZone. I don't see Denso brand at all. The cheapest plug is just a standard one for 1.99
Old 12-28-2010, 04:45 PM   #9
bankrobber
Should I torque them in? how many ft pounds?
Old 12-28-2010, 08:24 PM   #10
johnny_vitz
15 ft. lbs will do it. Might as well go for the iridiums at that price
Old 12-28-2010, 08:27 PM   #11
auxmike
auxmike's Avatar
Don't be pennywise pound foolish.
Break down and get the iridiums. That engine and it's managment system were designed around that part #.
Old 12-28-2010, 08:57 PM   #12
bankrobber
Oh yea, I plan to get NGK iridiums at AutoZone for 28 bucks for 4 of them.
I am planing to do some PM maintenance for the 100,000 service.
Wondering if I should dump antifreeze and refill? still on origional water pump.
I don't think I will buy from toyota as so many people lose pumps on the OEM fluid. Prestone form me
Old 12-28-2010, 11:15 PM   #13
severous01
ngk iridium or platinum...depending on how much you wanna spend or how long of an interval you want to change the plugs
Old 12-29-2010, 05:32 PM   #14
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
^^ur labeling name brands that u like that contradict the ones you dont like^^
AC Delco is a sister company to Champion and specialize in GM plugs, not so much imports.
Champion Ignition Company was the original distributor of spark plugs. Albert Champion was the president i think of this company. later did something with GM and split up and Albert went to making AC Spark Plugs and Stranahans bought the rights to make spark plugs from Champion Ignition Company and manufactured plugs under the "Champion" name..
just a little history lesson.. i did a paper on spark plugs back in high school =)
oh, and NGK has alot of japanese experience cuz they started originally supplying mostly to japanese automakers. then as they grew bigger over the years they expanded to other makes and models.
NGK FTW
Old 01-10-2011, 07:22 PM   #15
SignPirate
SignPirate's Avatar
Drives: 2007 Blue Yaris
I got my plugs from the dealer oem denso as well as my oil filters. They are about the same price as stuff you get at parts stores. Original Toyota will always fit and never void a warranty. I set up an account with my Toyota parts guy and he gives me 25% off. But I'm just saying.
SignPirate is offline   Reply With Quote
Old 03-31-2011, 10:38 AM   #16
swidd
Drives: Yaris HB
Does Toyota parts/Toyota dealers have a website with inventory and prices of parts?
swidd is offline   Reply With Quote
Old 03-31-2011, 11:05 AM   #17
sex
sex's Avatar
Drives: 09 5DR
some local dealers have their parts dept online, so i use http://www.toyotapartszone.com/
sex is offline   Reply With Quote
Old 04-03-2011, 11:36 AM   #18
swidd
Drives: Yaris HB
I just replaced spark plugs at ~87,000. Went with NGK Iridium IX. The old plugs were black/burnt quite a bit, exactly as the plug in the picture below. Probably wouldn't have hurt if I did it sooner.
Finally a DIY I didn't mess up.
spark plugs phenoyz DIY / Maintenance / Service 48 01-18-2023 03:26 PM
Spark plugs for yaris RS 2zrfe engine candy_red Yaris TS Talk 3 11-16-2009 02:20 PM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-02-2009 12:50 AM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 03:07 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 02:53 PM
