Old 08-22-2010, 09:22 PM   #1
rudolfoz
Drives: 08 Yaris Sedan AT
gas spills when filling up the tank
Hello everybody.
I've had my Yaris for 3 month now.
Every time I fill it up, the gas overflows the tank.
I am not sure what is the problem. I've never had this problem with any other car.
I was wondering if that is a common problem.
Thank you.
rudolfoz is offline   Reply With Quote
Old 08-23-2010, 07:53 AM   #2
Klink10
Klink10's Avatar
Not really. Change your fill up technique.
Old 08-23-2010, 11:23 AM   #3
Canuck
Drives: 07 5 door Hatchback
Make sure you insert the nozzle all the way and stop filling at the first stop of the pump.
Canuck is offline   Reply With Quote
Old 08-23-2010, 04:05 PM   #4
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
I dont recall right now but I think it says DO NOT TOP OFF.
You might be overfilling it or just fill up and wait till the bubbles comes down start filling again , But ur really not suposed to do that I guess.
Originally Posted by sw07gt
Old 08-23-2010, 09:22 PM   #5
rudolfoz
The problem is that the pump does not stop until it overflows.
I guess I just need to keep of track how many gallons to fill.
Old 08-23-2010, 10:37 PM   #6
djct_watt
Drives: 2010 NCP91 5spd
Happens at every pump, or do you always go to the same gas station?
Old 08-23-2010, 11:10 PM   #7
rudolfoz
it has happened with different pumps.
Last time my wife was filling up, and she had the same problem.
Old 08-23-2010, 11:47 PM   #8
djct_watt
http://science.howstuffworks.com/eng.../gas-pump5.htm
A good read.
You have 1 of two things happening:
1) You haven't put a good enough seal from the pump nozzle to the filler hole to create a pressure seal, not allowing the gas to build up to trigger the auto shut-off.
2) You have a leak somewhere in your tank or filler neck causing air to escape. Do you ever get a check engine light? A leak is possible, however unlikely, due to the sensitivity of auto shut-offs, and the massive leak necessary to render them ineffective. That and a fuel leak in your tank would drive your sensors crazy, giving you constant check engine lights.
Old 08-24-2010, 10:14 AM   #9
rudolfoz
So how do I fix that?
Old 08-24-2010, 10:17 AM   #10
djct_watt
Push it in as far as it will go.
Old 08-24-2010, 10:24 AM   #11
kimona
kimona's Avatar
Drives: 2014 White VITZ
Hold it a minute. Is this another joke thread?
Old 08-24-2010, 10:53 AM   #12
rudolfoz
I wish.
I am sick of spilling gas every time I fill up.
I have had several cars, and never had this problem.
it's not like I have never filled up gas before.
Old 08-24-2010, 11:03 AM   #13
djct_watt
Is your yaris newer than other cars? I believe newer cars didn't have an overfill vent... If I call correctly, it can make it easier to trip the sensor. My yaris doesn't do it, but I just remembered my scion xA did. One trick was to put the pump handle in upside down. Just make sure there is no tension on the hose, because when the shut-off kicks in, it can pop the pump nozzle out of the filler hole.
Old 08-24-2010, 11:09 AM   #14
kimona
kimona's Avatar
Take the car to the dealer and have the problem diagnosed. If indeed there is a problem, it should be covered under warranty.
Old 08-24-2010, 02:09 PM   #15
rudolfoz
I just went over 36 000 miles.
I guess it's too late.
I'll try the upside down filling technic.
Old 08-24-2010, 09:52 PM   #16
41magmag41
Drives: Loaded 2007 mica silver sedan
I think you'll find the yaris has 60000 mile drivedrain warranty and the fuel delivery system is part of that. Also I think she has an 80000 mile warranty on the emissions end and fuel vapor recovery is under that. This item should still be a warranty issue.
41magmag41 is offline   Reply With Quote
Old 11-15-2012, 01:51 PM   #17
cdilmore
Drives: 2010
41magmag41...
How did you resolve your "overflowing gas while filling" issue? When I picked up my 2010 Yaris from the dealer, she said: I just filled it. In fact, it overflowed.
I thought nothing of it until today - my first fill-up. Even with the nozzle completely inserted, the thing didn't trip & turn off. Just gushed gas right out the neck & down the car.
Thanks for letting me know if you changed your technique, or if Toyota performed a mechanical miracle. And thanks!
Chuck
cdilmore is offline   Reply With Quote
Old 08-24-2010, 03:27 PM   #18
You didn't answer if the check engine light is on. And, if it's not, does it come on for a second when you initially turn the key?
Does the spilled fuel come out from around the pump nozzle (and spill down the side of the car) or does it spill out under the car?
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 07:41 PM
Had problems filling the gas / petrol tank? fidgell General Yaris / Vitz Discussion 6 08-27-2010 04:47 PM
Filling up using spare gas tank. Yarimoto Fuel Economy Forum 5 08-19-2009 05:29 PM
Don't overfill your gas tank! kimona General Yaris / Vitz Discussion 19 07-17-2007 02:15 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 09:07 AM
