Old 04-11-2015, 02:40 PM   #1
ivanstepul
Drives: 08 hatchback
Drag Racing yaris 15.969
I went to the drags a while ago and posted best time of 15.969
mods
manual trans
intake
header
midpipe(with stock muffler)
weight reduction ocd( i took off front license plate, folded mirrors, took off antenna, hubcaps, loose change, carpet, passenger seat)
ivanstepul is offline   Reply With Quote
Old 04-11-2015, 03:36 PM   #2
428CobraJet
Drives: '09 Yaris 3dr, 13 F150rcsb 5.0
That's good....i see you're running 17 in tires. Is the diameter different from original? Ie...change in gear ratio?
You are what you drive.
428CobraJet is offline   Reply With Quote
Old 04-11-2015, 10:02 PM   #3
ivanstepul
actually when I ran the quarter I had 15 inch rims with stock size tires 15/65/185 but the tires were really nice they were the altimax rt tires
Old 04-11-2015, 10:07 PM   #4
ivanstepul
no change in gear ratio stock trany
Old 04-11-2015, 10:20 PM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
If your tires are a different diameter than stock, it changes the effective great ratio. It's an easy way to get more torque without tearing your gearbox apart.
Old 04-11-2015, 10:29 PM   #6
ivanstepul
I'm not a science expert but there is more torque if the rim/tire is a smaller diameter right?
Old 04-11-2015, 10:43 PM   #7
CrankyOldMan
Correct. You can always trade torque for speed by going larger, and vice versa.
Old 04-11-2015, 08:05 PM   #8
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Not bad. Mine with a soft launch runs 16.3s
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 04-11-2015, 08:17 PM   #9
CrankyOldMan
I tried that a few times with my AutoX tires and almost broke 17. Must be my technique is crap, because that was after the supercharger install.
Old 04-13-2015, 08:51 AM   #10
Idahotom
Drives: 2008 5 sp. LB
Very cool.
And I thought I had MY HB stripped down, I'm a slacker, leaving the carpet and front passenger seat in!
Idahotom is offline   Reply With Quote
Old 04-13-2015, 10:37 AM   #11
Astroman
Modded Moderator
Astroman's Avatar
You missed this: OFFICIAL 1/4 mile time thread *TIMESLIPS REQUIRED*
Manual or auto? Post your slip, any modifications, and what transmission.
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 04:13 AM
