![]() Drives: 2007 Hatchback Auto Join Date: Jan 2022
No crank non-starter/solenoid issue Help PLZ
Went into a ditch then have let the car sit ever since, the car hasn't run for a year now. I don't know if I turned it over at all after the wreck at all which doesn't help to know if something was damaged then.
I hit the ground and a big log pretty hard but other than the bumper and radiator things look good. The shift lever on front of transmission was bent and shift cable broke off lever, after bending it back I am able to move it into park but with no change to start condition. I know there are probably several things that could cause this, here is what I have done so far... New battery and no crank or click, engine does crank when supplying 12 volts directly to solenoid terminal (small signal wire). Tested shift lever neutral safety switch, terminals have continuity when in park position and non otherwise so looks functional to me. Tried starting with shift lever in park/neutral positions and with brake on. Checked fuses ( I think i found them all). Checked Starter and Ignition Relay they are good. Any help would be appreciated, it would really be nice to get my Yaris going again to save money on gas. Thanks in advance, Hiro. Pictures of how the car looks now and of transmission shift lever/neutral safety switch: Last edited by Hiro; 01-12-2022 at 01:22 AM. |
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
Engine may be locked up.
Engine seams fine
After replacing the broken shift cable it started right up, I think that the shift lever was not going all the way into position.
| Issue where dashlights either turn on or fade on when car off | razingman | DIY / Maintenance / Service | 0 | 01-17-2021 12:24 PM |
| Random No Start Issue | Darkhorse6 | DIY / Maintenance / Service | 6 | 05-11-2016 12:46 AM |
| yaris voltage issue | yaris2010RS | DIY / Maintenance / Service | 11 | 12-29-2012 04:20 PM |
| 08 HB DRL Issue | BruceLee | Cosmetic Modifications (Exterior/Interior) | 3 | 02-18-2012 10:59 PM |
| Minor issue with NST crank pulley at takeoff | YarisSedan | Performance Modifications | 0 | 05-12-2009 01:06 AM |
