Old 04-19-2015, 06:19 PM   #1
Portugal329
Drives: 2009 Yaris Sedan
2009 sedan Foglight install help
im in the process of installing fogs in my 09 sedan i have the light stalk and oem relay im trying to install the wires in the box under the hood im just trying to figure out if each seperate +wire goes into the harness or can i connect them together and then split into the harness hole 1+2. Im talking about the microimage install kit thanks
Portugal329 is offline   Reply With Quote
Old 04-19-2015, 06:31 PM   #2
You want to use both pins 1 and 2. From there you can common both together with both of the fog light positive wires, but the key is using both terminals in the fuse box connector to distribute the current draw between two pins, as one alone is not rated for the current of both bulbs.
Old 04-19-2015, 06:37 PM   #3
Portugal329
Ok so the +wire from the left fog goes into pin 1 and the +wire from the right fog goes into pin 2 or vice versa correct?
Old 04-19-2015, 06:44 PM   #4
Portugal329
Ok i reread your answer and i understand now thank you for your reply this will be my project for next week again thank you very much
fog lights, foglights, fogs, sedan
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 10:22 AM
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
2007 Sedan HU, Amp, Speaker install Crackerballer In Car Entertainment + Electronics (audio / video / alarm) 15 11-14-2011 08:47 PM
2009 Yaris Sedan vs 2009 Scion XD Jungle Rot New YARIS Purchase Forum 32 02-23-2009 06:40 PM
