Old 05-22-2015, 09:53 AM   #1
rossman
Drives: 2006 YARIS RS
ABS Sensor Replacement
Hi All,
I am looking to replace these sensors or the cabling as I am tired of looking at the lights on my dash. I know this is a common problem, corrosion of the connectors.
Where are the connectors & sensors located?
Does anyone have any good pictures or a DIY of this process?
Thanks,
Andrew
rossman is offline   Reply With Quote
Old 05-22-2015, 12:00 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
It is usually the rear ABS sensors the problem. If you look at the back of the drum, you will see 1 wire coming out with a connector (this is the abs sensor cable) and the other one is the brake line (rubber tube)
Old 05-22-2015, 02:43 PM   #3
rossman
Thanks, I will check it out tonight.
FRONT ABS htschek DIY / Maintenance / Service 1 08-05-2013 10:14 PM
ABS brakes / Would you buy a Yaris without them? 3cyltrbo General Yaris / Vitz Discussion 66 03-26-2011 09:21 PM
ABS LIGHT & E BRAKE LIGHT rossman DIY / Maintenance / Service 5 02-26-2010 12:09 AM
Adding ABS to a Yaris tadc Performance Modifications 1 02-14-2010 04:56 PM
What's with ABS? jgag123 Canada 9 01-01-2009 07:04 PM
