![]() Drives: 2006 Toyota Yaris Join Date: Sep 2015
Vehicle - 2006 Yaris
Symptoms are as follows; Start car, disengage parking break - DRL's do not come on. Turn headlight switch to park light position - lights do not come on but headlight indicator on panel illuminates. Turn switch further for headlights - the driver headlight comes on very dimly and front driver side park light turns on; no other lights come on. Push lever forward for high beams - high beams and all parking lights turn on as per normal. This is how I have been driving for the past couple days. I disconnected the DRL relay box and I still have the same symptoms as above. Fuses seem to be fine although I may not have checked them all as they are labelled with limited descriptive acronyms. |
This issue has been resolved.
Both headlights went at the same time and caused all these symptoms. I've only had them go one at a time so I haven't seen what happens when both go at once. The symptoms through me off when trying to troubleshoot the issue. A first for me. |
Welcome to the forum.... You came to the right place for problem solving help about the Yaris. At the same time we welcome you contributions in solving problems as well....you did good on both fronts.
| Tags |
| drl, headlight, parking light |
| park lights not working | koppe | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 06-06-2025 03:24 AM |
| DC Sports CAI interference problem with fog lights | beaker | Performance Modifications | 5 | 09-15-2014 08:26 PM |
| Problem with lights. | Grantstead | DIY / Maintenance / Service | 9 | 07-11-2011 03:14 PM |
| BIG driving lights.... how? | jonismyname | Cosmetic Modifications (Exterior/Interior) | 22 | 09-30-2010 08:54 AM |
