Old 06-10-2015, 08:59 PM   #1
rider99
Drives: 2007 yaris sedan
Lightening and dash warning lights
Driving my07 yaris sedan on interstate lightening hit close maybe hit car no visual signs. All warning lights came on dash no tach or air wont work a day later and auto trans won't shift. I checked the two fuses at battery cable. What's your opinion please I need help
rider99 is offline   Reply With Quote
Old 06-10-2015, 09:40 PM   #2
Wow!
Is anything electrical actually working at the moment?
Old 06-10-2015, 10:00 PM   #3
rider99
Yes car will run lights windows door locks mirrors interior lights
Old 06-10-2015, 10:03 PM   #4
rider99
Radio also works
Old 06-10-2015, 10:40 PM   #5
OK. In that case the not shifting may be the 10A STOP, 10A GAUGE, or 7.5A ACC2 fuses, which are all located under the bottom of the dash on the driver's side.
Old 06-10-2015, 10:41 PM   #6
Also, check the 10A ETCS fuse in the under hood fuse box.
Old 06-10-2015, 11:01 PM   #7
rider99
I have checked all fuses beside battery under hood and all fuses under driver side dash...all good. I do not know how to check any of the relay's or the larger square clear top fuses
Old 06-10-2015, 11:02 PM   #8
rider99
When I put the car in drive it dies but if I pull it down in low gear I can take PFF and manual shift.
Old 06-10-2015, 11:03 PM   #9
rider99
Off
Old 06-10-2015, 11:20 PM   #10
Does the check engine light come on when you turn the ignition on and then go off when you start the car?
Old 06-10-2015, 11:34 PM   #11
rider99
It does come on when ignition is on and off when started
Old 06-10-2015, 11:36 PM   #12
rider99
Cool light, batt, air bag, brake, p/s and abs are staying on
Old 06-11-2015, 06:44 AM   #13
OK. So the ECM is alive, but some systems are not working. I would check the large fusible links on the battery (pop the red cover and shine a flashlight on them to see if you can see any breaks in the metal under the clear plastic).
Old 06-11-2015, 07:36 AM   #14
rider99
I did slide a clear cover off and see two fusible links. I took the battery out so I could get a better look at it and all seemed fine. when inspecting the cable end I felt as tho the white wire coming off the battery cable terminal fuse block felt funny I would have ohm it but couldn't figure out were it went.
Old 06-11-2015, 07:52 PM   #15
That big white one goes from the 60A MAIN fuse on the battery connector to the constant power fuses in the under hood fuse panel (ALT-S, DOME, ST, ECU-B, ETCS, HAZ, H-LP LH, H-LP RH).
With the other three black ones that come off of the positive terminal, they are all connected to the 120A ALT fuse on the terminal. One goes straight to the alternator, the second to another group of fuses (HTR SUB2, EPS, ABS, HTR, ABS2, HTR SUB1, and RDI), and the third to the under dash fuse panel.
Old 06-11-2015, 08:21 PM   #16
rider99
With that being said I take it that if my hazard lights dome lights work that white wire is good
Old 06-11-2015, 09:12 PM   #17
rider99
More checking this evening and found
Old 06-11-2015, 09:14 PM   #18
rider99
That I'm only getting 11.5 volts from alternater
