Old 09-29-2015, 07:00 PM   #1
Cfc
Drives: 2007 Toyota Yaris
Overheating issue
A few weeks ago my 2007 Yaris started to overheat. Based on the issues I was having I changed the thermostat and water pump. I am still having the issue. The heater will not blow hot air and the car will still over heat. I can't find any leaks. I may also have air in the system. I have tried to allowing the car to run and adding coolant when the fan kicks on. Could air pockets be the cause? Any help is greatly appreciated.
Cfc is offline   Reply With Quote
Old 09-29-2015, 07:08 PM   #2
Air pockets could definitely be part of it, particularly with the heater core not working. There is a petcock on the back of the engine that must be opened when refilling the system otherwise a large pocket of air is trapped.
Old 09-29-2015, 07:10 PM   #3
Cfc
Should I drain it. Open the petcock on the back and refill it. Or should I just open it now and try it?
Old 09-29-2015, 07:49 PM   #4
If you open it now you will drain some fluid. I would put a pan under it, and open the petcock and let it drain until it stop from there. Then, start refilling the system until it starts to run out the petcock. Once it does, close the petcock, finish refilling and run the engine with the filler cap open until the bubbles stop.
If you fill the system without opening the petcock, no matter how much you run it with the cap open you will not get all of the air out.
Old 09-29-2015, 07:59 PM   #5
Cfc
Do you have a link to a video or diagram of the petcock?
Old 09-29-2015, 09:04 PM   #6
Here is a view of it from under the car. Once you understand where it is, you can easily access it from above. A 10mm socket is necessary to open it.
Old 09-29-2015, 07:32 PM   #7
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
What works well is leaving the rad cap off turn heat on full inside car and run car till u get heat from vents by leaving the rad cap off u will push out air out of the system, you may need to Rev the car up for a bit...this works well every time.
Sent from my Moto X Play
Old 09-29-2015, 08:56 PM   #8
tmontague
tmontague's Avatar
^ya Scott, I'm curious as to what you find is the easiest method to access the petcock and what tool you use to open and close it.
To the OP, check the temp of your upper and lower rad hoses, could be a blockage of some sort not allowing heater core to heat up and/or not allowing fluid to fully circulate hence the over heat
Old 09-30-2015, 07:35 AM   #9
ex-x-fire
You could also purge air at the heater hoses, remember air rises. I like to use a heater hose pick.
Overheating Issue YanMinor DIY / Maintenance / Service 46 07-07-2018 02:09 PM
Overheating problems scumfromohio DIY / Maintenance / Service 24 04-18-2014 02:09 AM
yaris voltage issue yaris2010RS DIY / Maintenance / Service 11 12-29-2012 04:20 PM
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 10:59 PM
