Drives: 2020 yaris Join Date: Aug 2022
I have a 2020 yaris and I'm having the hardest time finding any factory torque specs for anything. Specifically I think my front axle nut is loose but any info on how I can get the other specs would be amazing! I can't find a maintenance manual or anything for it, I've also looked for mazda 2 specs and that's not any better.
![]() ![]() Drives: 2007 4dr sedan Join Date: Jun 2009
See if this helps: https://cardiagn.com/toyota-yaris-20...owners-manual/
https://techtips.alleuro.com/wp-cont...orque-Spec.pdf page 21. Should get you close enough.
| Front hub Axle nut torque process | esse10 | DIY / Maintenance / Service | 2 | 05-19-2022 05:28 PM |
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 12:56 PM |
| Front Lower Arms and Ball Joint Torque Specs for 2012 Toyota Yaris LE Hatchback | ToughGuy | DIY / Maintenance / Service | 0 | 12-23-2020 09:38 PM |
| TRD Delrin Rear Axle Bushing Collars | tmontague | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 12-15-2019 08:50 PM |
| Wheel bearing / Outer TRE / Control Arm replacement howto | shepd | DIY / Maintenance / Service | 3 | 09-14-2015 05:20 PM |
