Old 09-27-2015, 06:49 PM   #1
Toolaholic
Drives: Olive yaris,FRS, Dakota R/T
Installing struts in my yaris
Hi I took plenty of pictures. This is how I removed and replaced my struts. I wish I would have bought KYB quick struts as compress the springs and pressing in near bearings toke alot of time. 2007 yaris w/ 65K. Yes it was early but I can feel a big improvement!
Toolaholic is offline   Reply With Quote
Old 09-27-2015, 06:51 PM   #2
Toolaholic
You can remove outer bolts and leave metal cowl in place and slide on in underneath it!
Old 09-27-2015, 06:53 PM   #3
Toolaholic
I left all washer hoses connected
Old 09-27-2015, 06:55 PM   #4
Toolaholic
Old 09-27-2015, 06:57 PM   #5
Toolaholic
Lfting with a hein wrener 2 ton jack. Jack stands at the sills w/ slots for the pinch welds. Had to have the front wheels on 2x lumber to fit hein Werner jack under car.
Old 09-27-2015, 07:00 PM   #6
Toolaholic
impact w/ a 17mm impact socket on upper end link
Old 09-27-2015, 07:02 PM   #7
Toolaholic
removing lower link from swaybar. i bought moogs as rteplacements. hint: if really rusty use a 7/32 asa a 6mm does not fit a corroded allen hole. Wrench is a super long sk g pro 17x19 ratchetimg spline wrench. plenty of kroil oil used. These slowly came off even with all that leverage.upper link to strut was impacted out. lowers were removed w/ allen and wrench
Old 09-27-2015, 07:06 PM   #8
Toolaholic
uppers were eventually impacted out. allen cammed out. vice grips came into play
Old 09-27-2015, 07:08 PM   #9
Toolaholic
Big armstrong 12-994 18 inch long locking flex head 1.2 drive ratchet on the nut. A big proto 17x19 on the bolt. These are on tight. Lower stut mount bolts and nuts are 19mm. Since I used 1/2 drive i didnt need a deep socket for nut.
Old 09-27-2015, 07:15 PM   #10
Toolaholic
a fter I broke nut loose,I switched from big ratchet to the sk g pro 17x19 ratcheting wrench
Old 09-27-2015, 07:17 PM   #11
Toolaholic
spring compressor time! I used this one: http://www.amazon.com/s/ref=nb_sb_no...words=atd+7550
Old 09-27-2015, 07:20 PM   #12
Toolaholic
Old 09-27-2015, 07:23 PM   #13
Toolaholic
Old 09-27-2015, 07:25 PM   #14
Toolaholic
when spring was compressed enough not to be touching strut cover, I zipped the 17mm now off w/ a 17mm deep impact socket driven by a Milwaukee v18 impact wrench.
Old 09-27-2015, 07:27 PM   #15
Toolaholic
I drove bearing out of strut plate w/ a sk punch and ballpeen hammer! One tap out! Put upside down like this in vice. Put punch in hole.
Old 09-27-2015, 07:29 PM   #16
Toolaholic
top view
Old 09-27-2015, 07:31 PM   #17
Toolaholic
new vs old
Old 09-27-2015, 07:32 PM   #18
Toolaholic
hey look no spring or boot
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 04:55 AM
Yaris vs Celica jesh462 New YARIS Purchase Forum 11 10-19-2012 12:49 AM
Installing USB Power in the yaris? deathchimp DIY / Maintenance / Service 2 03-25-2011 03:39 PM
Installing Amp 53 Reg Yaris e11smt In Car Entertainment + Electronics (audio / video / alarm) 1 12-22-2009 08:54 AM
