![]() ![]() Drives: 2013 Yaris LE 5Dr Join Date: Nov 2014
09 with yellow/foggy headlights
My wife's 09 Yaris 5dr is always parked outside and we don't wash/wax like we should and the headlamps are getting less effective. I've just replaced the bulbs with new ones, hoping it was that, but it's definitely the yellow/foggyness on the headlamps.
I've polished my headlamps before on other cars, and no matter what I did, about a year later it always came back, even when regularly applying protectant. I'm thinking of ordering the LED foglights I've seen here, hoping they would compensate, but I might instead just buy new headlamps from online or something. What have you done? Any advice for someone without a lot of time free?
Looking for fun! |
Seen it?
http://www.yarisworld.com/forums/showthread.php?t=53750 I think, short of sanding down and applying a fresh coat of clear, shelf products will give you a year max before needing to go at them again.
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
^this. minus applying a coat of clear.
Sand them down with 800 Grit, then 1000, then 2500 or 4000 (don't go lower than 2500 for the last sand down) hand polish using a hand-type rubbing compound. (safer than buffing machine + machine rubbing compound IMO). VOILA! it should last you a good 2 years at the least. don't use any sort of protectant. if it doesnt, it means that youre headlights are exposed to good amount of UV rays--be it the sun or from the HID bulbs. |
![]() Drives: 09 yrs Join Date: Oct 2015
I just wet sand with 2,000 grit and buff it out with an orbital polisher using Mothers compound and finisher. Comes out clear as glass.
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 09:42 PM |
| Sedan HID Projector Retrofit Headlights | !yaris! | Cosmetic Modifications (Exterior/Interior) | 10 | 10-26-2017 03:31 AM |
| Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal | V70R_Blackbrick | Cosmetic Modifications (Exterior/Interior) | 26 | 11-27-2013 11:14 PM |
| 2010 yaris Projector headlights | yaris2010RS | Items for Sale by private party | 9 | 01-09-2012 06:31 PM |
| Best Aftermarket Headlights | MadMax | Cosmetic Modifications (Exterior/Interior) | 3 | 06-04-2009 07:50 PM |
