Old 02-18-2015, 03:23 PM   #1
BennyLava
Drives: 1987 Silverado
tune up time. which components
Well I'm assuming it's tune up time, at least. The car has 120k miles on it, and this will be its first tune up. Anyone know the exact mileage you're supposed to do it?
Also the spark plugs are iridium from the factory. But i would like to try out those e3 plugs. Is there any reason i shouldn't?
As for the O2 sensor, I'm not sure what to go with.
Got a wix air filter.
Fuel filter and plug wires I don't know about. I'd prefer Toyota quality. Any recommendations?
Old 02-18-2015, 04:07 PM   #2
matti
Drives: 2017 Yaris L (5sp manual)
What model year do you have?
I'm far from an auto expert, but isn't the idea of a "tune-up" a thing of the past? I think you just should follow the maintenance schedule in your owner's manual? Of course, if you have problems with certain components, those should be addressed.
I'm sure others with more experience will chime in. (I'm also curious about what others think, too.)
matti is offline   Reply With Quote
Old 02-18-2015, 07:34 PM   #3
nookandcrannycar
IIRC, the schedule in the owner's manual = replace the spark plugs at 100,000 miles. I waited until after 207,000 miles on my '07. I'll change the spark plugs at or before 100,000 miles on my '14.
Old 02-18-2015, 08:42 PM   #4
sheekeebut
Minimalist
Drives: 07 silver sedan
I'd go with the OEM (Denso?) Iridiums, just to save me the hassle of having to changing them within the second half of this car's foreseeable life.
Lots of Internet chatter about E3's overly enthusiastic claims about its DiamondFire electrodes.
sheekeebut is offline   Reply With Quote
Old 02-18-2015, 09:27 PM   #5
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Stick with denso or ngk. Mine developed a miss at 65k so i put in fresh denso iridiums and all is well. I drive the balls off of mine so maybe thats why i went thru them so fast.
There is no wires...its individual coil on plug.
Consider a belt while your at it...its like 8 bucks. Also get some MAF sensor cleaner spray and clean the MAF. That should make a noticeable difference since it has probably never been done.
O2s dont need to be changed until they are throwing a slow response code or likewise. So save your money. If and when you need to Denso or NTK.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 02-18-2015, 11:43 PM   #6
sheekeebut
Minimalist
Good point with the MAF sensor cleaner. If you've got the extra 5 minutes while changing the air filter (hopefully regularly and not just at tune-up time), might as well clean off that sensor. Dirty MAF sensor was what caused the surging and rough idle on the wife's Hyundai.
Old 02-19-2015, 06:07 AM   #7
BennyLava
Sorry its a 2009. I guess its not really called a "tune up" anymore, although maybe that term has evolved to simply cover the modern version of this process.
To address a question you posed, the plugs definitely need replaced at some point as they will finally wear out. This may take longer than it used to but they have a finite life span and its a lot shorter than that of the engine. Something tells me these engines will easily see 350k or more, if properly maintained.
As for the plug wires, I figured it was some kind of coil thing, but I've seen newer vehicles that have the individual coil pack setup, but still have a tiny plugwire going from that to the plug lol. Like a 6 inch long one. It was the old style that would still eventually wear out.
Thanks for the recommendation on the O2 sensor, I'll just skip it for another 100k miles, or until it fails.
Now as for Denso, I could have sworn that was honda. Does toyota have a house brand like Ford has motorcraft, and GM has AcDelco?
Yes the air filter I change more often than that, and thanks for the recommendation on the MAF sensor. I completely forgot about that. So I'll get that cleaned up.
As for the belt that one member talked about, which belt were you referring to? I'll admit I haven't ever really had a good root around in the engine, hadn't really had to yet.
Old 02-20-2015, 08:11 PM   #8
nookandcrannycar
Two members, yaris9876 and trini_per4mance, have well over 400,000 miles on their original engines. Trini has over 535,000 miles on his original engine. Both of them also made it over 400,000 miles with their original clutches.
Old 02-21-2015, 01:22 AM   #9
nookandcrannycar
Another member, Mazilla, bought a courier company with a fleet of 20 vehicles, each a Yaris. The mileage on these 20 ranged, IIRC, from 350k to 500k miles. He sold 19 of them, and kept one for himself.
Old 02-19-2015, 09:42 AM   #10
IllusionX
Drives: 07 Yaris Sedan Aero
Toyota uses Denso parts.
Old 02-19-2015, 09:45 AM   #11
bronsin
bronsin's Avatar
Fuel filter NOT a regular service item. As long as you don't get bad gas its good until you do.
Toyota AF the BEST I have seen. But never saw a wix.
O2 sensor leave it alone until it throws a code my 2 cents.
Sparkplug wires NOT necessary at any mileage on this car. My wifes 05 Camry has original plugs and wires. Runs fine.
Good luck and tell us what happens!
Old 02-20-2015, 08:15 AM   #12
BennyLava
Thanks for the reply.
However, as one member said, it may be that you need to replace the plugs at 100k miles. If the manual says so, that is. Your wife's car may be suffering some decreased fuel mileage as a result of never having changed them. Even if its not actually running badly.
Old 02-20-2015, 08:23 PM   #13
nookandcrannycar
How many miles does your wife's Camry have on it ? Not changing the spark plugs started to = adverse performance on my '07 at about 203,000-204,000 miles. I ignored that for a few thousand miles and finally had the plugs replaced at about 207,000-208,000 miles. Great improvement.
Doesn't your wife's Camry have at least a 1.8 L (not the 1.5 L the Yaris has) ?
Old 02-21-2015, 10:27 AM   #14
bronsin
bronsin's Avatar
About 120k now. 2.4 liter four cylinder engine. Might do the plugs this spring when it warms up...
A few years ago at a tech meet for my ST1300 motorcycle, I saw an ST13 with 75k miles on the standard plugs. The motor ran flawless. As the local Honda dealer didn't have new ones so we just gapped and reinstalled the old ones.
Bike ran like a watch!
Old 02-22-2015, 12:49 PM   #15
nookandcrannycar
I'd imagine one reason that Toyota recommends replacement at 100k miles is because most owners don't know how to do that.
Old 10-12-2015, 04:21 PM   #16
BennyLava
Why would they lose their factory gap? Never heard of this.
Old 02-20-2015, 09:10 PM   #17
malibuguy
Obsessed with 1.5L
Camry is coil on plug too...no wires
-96 Tercel 4dr
Old 02-21-2015, 05:37 AM   #18
bairjo
Although this doesn't fall under the "tune up" list of to do's, there has been some discussion that a drain and fill of the AT fluid might be in order at this time. There really is not a clear answer for that in the owners manual that i could find and if you read the threads on this, every dealer it seems has a different answer about when it needs done. Maybe I should not of brought it up on this thread...sorry if that is the case, just a thought you may want to consider it.
Guess that tune! fnkngrv Off-topic / Other Cars / Everything else Discussions 23 06-05-2014 06:58 PM
Another question about car audio wiring for rear components YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 0 08-16-2010 10:39 PM
Time Attack Invades Houston! Rollmodl Southwest 8 05-03-2010 09:00 PM
First time AutoX with the Yaris Keith Tinari Tracking, Racing, Auto-X Forum 52 11-20-2009 03:38 AM
time zones Sodium Duck Suggestions - Feedback - Questions 13 01-06-2009 09:23 PM
