Old 07-16-2013, 10:32 PM   #1
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Finally, my motor went.
I must say, I pushed it for a long time... so this was bound to happen. I was simply driving home a few nights ago and did a full boost (30psi) pull, right at redline in 2nd gear I got valve float. I have had the rev limiter set at 7500 for about 5 months, but it was pure luck I made it that long on a stock head. I was barely able to make it home, the car barely ran.
Im hoping the bottom end is ok, and just some minor damage done to piston tops.
Garm, I noticed you carry upgraded valve springs, Ill be contacting you soon about those and a intake manifold. Also cam options, if there are any.
I was able to squeeze 60k miles out of this motor without any snags until now!
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 07-16-2013, 10:40 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
The BC Valves come highly regarded. There is also the JUN Cam pair designed specifically for turbo applications.
Old 07-16-2013, 11:52 PM   #3
You did great, made us all proud with your build. We can grind cams for half what JUN charges, I would never pay their prices.
Old 07-17-2013, 01:47 PM   #4
kou
Drives: 08 lb
You had great numbers before and beat it up for a long time so I cant wait for your next build.
Old 07-17-2013, 07:39 PM   #5
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
*Engine :P
but besides that, it is time to go crazy, you know grind some cams, up grade the valves, port and polish, all that stuff that makes more ponies
Old 07-17-2013, 08:38 PM   #6
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Regrind cams sounds fine to me. Ill do those, springs, and possible port and polish. I am interested in the golden eagle manifold, what tb flange options are there?
Ptuning.com
Old 07-17-2013, 09:34 PM   #7
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
Do you have a link to your build thread? I don't want to ask a bunch of questions that you have already posted answers to.
Did you do a teardown already? Interested to see what the motor internals look like.
The Spectacle is offline   Reply With Quote
Old 07-18-2013, 08:40 AM   #8
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I don't see an actual full thread build. But if you look up his name and all the threads Blown xA started, you will find alot of the answers you seek.
http://yarisworld.com/forums/search....archid=1580961
-Derrick-
Old 07-18-2013, 06:21 PM   #9
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I never made a build tread, Im weird lol
Ptuning.com
Old 07-18-2013, 06:30 PM   #10
Whatever you want, it comes 1ZZ/1NZ, but we've made 1NZ cable (xA/xB) and larger (70mm) flanges as well. All available.
Old 07-18-2013, 06:31 PM   #11
Do I smell 10's on the horizon?
Old 07-18-2013, 10:19 PM   #12
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
that is the plan yep. I need another 50-70hp, that should get me there if not very close .
Ptuning.com
Old 07-19-2013, 01:34 PM   #13
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Hey when you ran that 12.9 in your sig, what was your whp?
Old 07-19-2013, 03:34 PM   #14
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
good news for this little guys!
Old 07-19-2013, 05:29 PM   #15
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
286whp at that time, with oem steelies. The 11.9 was with slicks and 318whp. I am currently at 352whp but haven't run it yet ( not that I could now anyays )
Ptuning.com
Old 07-20-2013, 12:33 AM   #16
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Have you popped the top see what failed yet?
Old 07-20-2013, 07:55 AM   #17
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Ill probably do so next month, have a bore scope at the shop too. Right now, my focus is elsewhere (downhill/streetluge racing).
Ptuning.com
Old 07-21-2013, 12:32 AM   #18
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
I sad to hear about your motor but i think the motor has had a good life. good luck on your next build.
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
FINALLY!! nickhjort DIY / Maintenance / Service 18 01-16-2009 11:09 PM
I'm FINALLY getting my Yaris! sherryberry New YARIS Purchase Forum 22 07-09-2007 12:08 PM
Finally! KittenRD New YARIS Purchase Forum 6 01-01-2007 09:16 PM
