Old 10-15-2015, 02:57 AM   #1
bairjo
How hot should my brake rotors get?
I know this is a Yaris forum, but I just did my wife's Rav4 brakes...new rotors & pads. Shooting a laser at the rotors...any idea how hot front rotors should get?...ball park. I drove around town hitting 40 mph tops applying the brakes often but not real hard. I was getting around 300 degrees F. That seemed a little high. I'm sure if I hit the highway and did some test stops/slowdowns it would be higher. Should I be concerned? Once again, I realize this a Yaris forum but the information I hope to get would be helpful to us Yaris enthusiast. Also, the input from you guys is always much more in depth than the folks over on the Rav4 forum.
Old 10-15-2015, 07:39 AM   #2
bronsin
bronsin's Avatar
Sounds perfectly normal to me.
Old 10-15-2015, 10:09 AM   #3
bairjo
thank you....I guess I am just a little cautious since I had a problem with my sons Avalon years ago....not sure how hot the one with the bad caliper got but the rotor was a smoking blue when I took it on the freeway test run.
Old 10-15-2015, 03:01 PM   #4
bronsin
bronsin's Avatar
That's too hot unless youre coming down Pikes Peak.
Old 11-10-2015, 01:30 AM   #5
SirDigby
Drives: 2007 yaris 3 door
5000 degrees!!!
no, that's not right....
Old 11-10-2015, 10:40 AM   #6
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
As long as they're both the same.
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 09:50 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 09:05 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 08:34 PM
Anyone have their brake pedal go rock hard on hot days? LtNoogie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 07-28-2009 12:20 PM
First thoughts: Carbotech XP8 pads and slotted rotors jkuchta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 12-19-2008 11:21 AM
