Old 09-12-2015, 03:40 PM   #1
attrapereves
Drives: 2010 Yaris 2dr 5spd
Clutch survey
I wanted to gather some information on here about our clutches. Let's list...
Year:
Miles:
Original clutch? If no, how many miles when you replaced it?
I bought my car used with 72,000mi and am worried about having to replace the clutch in the next few years. The horrible throttle often makes me accidentally give the car close to 3000rpm when starting from a complete stop. No idea how the previous owner drove the car.
If I took my car to a transmission shop, could they tell me how my clutch is doing or how much life may be left?
attrapereves is offline   Reply With Quote
Old 09-13-2015, 01:23 AM   #2
nookandcrannycar
My car years and mileage are in my signature details (show up on each of my posts). Original clutch in both of them.
Park your Yaris in a flat, open space (an uncrowded parking lot), and you can DIY. Do the Standard Clutch Test posted by Yarisworld member djct watt. See post #12 on the link below for this Standard Clutch Test post:
http://www.yarisworld.com/forums/sho...ght=45k+clutch
Old 09-13-2015, 05:27 AM   #3
Yaristeve
Drives: 3-door hatch
2011 3-door.
Purchased November 1, 2010.
143,000 miles.
Original clutch.
But I think it is going to need replacement soon. I have the following symptoms:
1. On cold mornings, during the first couple miles, my clutch chatters or shudders when taking off from a stop. It did not do this when new and only started recently. But chattering could be a symptom of other problems such as burnt/glazed disk or a heat-checked flywheel.
2. The clutch seems to be engaging much closer to the floor than when I first bought it.
But it has not started slipping, either during normal driving or when I test it.
My test is a little different than the one posted above:
Find a clear stretch of road. Start off driving normally and at about 20MPH, instead of shifting into 2nd, shift into 4th. Briefly punch the throttle about 30-40% then let go. If your engine revs up but the car does not accelerate accordingly, you need a new clutch. If your engine starts lugging or bogging, the clutch is okay. It is basically the same principle as the test as posted above but in a higher part of the power band. I perform this little test every few months on all my cars after they've accumulated a lot of miles.
Old 09-14-2015, 09:39 AM   #4
fourbangingfun
fourbangingfun's Avatar
155k miles. 07 Sedan.
Clutch chatters on cold starts in 1st. Doesn't slip at all. Gonna milk it as long as possible.
fourbangingfun is offline   Reply With Quote
Old 09-14-2015, 04:43 PM   #5
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
08 Sedan
200K kilometers.
just replaced clutch as it was juddering/shuddering on take off,
i figured at 200K its probably gonna let go sooner than later, i'd rather have my mechanic fix it than some one i dont know while i'm driving half way across the country.
Have Yaris will travel..
Old 09-18-2015, 07:12 PM   #6
Lux
Lux's Avatar
Drives: NCP91
108'000 km on factory clutch assembly.
Driven very hard and raced often.
Frequent 4'000 rpm clutch dump launches.
Double-clutched rev-matched downshifts every time, every day since purchase.
Originally Posted by jambo101 View Post
08 Sedan
200K kilometers.
Change your engine mount.
Lux is offline   Reply With Quote
Old 09-20-2015, 01:22 PM   #7
MUSKOKA800
MUSKOKA800's Avatar
2008 Sedan. ~185,000 Kilometers. Plenty of aftermarket power adders.
Blitz since about 60,000 Km.
Original clutch. Occasional shudder during cold first gear take-offs.
Bite is good. Disengagement however seems a bit deeper in the pedal throw than originally. May need a hydraulic fluid bleed???
Old 10-04-2015, 07:26 PM   #8
SirDigby
Drives: 2007 yaris 3 door
do you do this because Fast&Furious told you to? why would you do this?? all this will do is make your master cylinder wear out twice as fast! do you have a straight cut gears in your trans? are you missing synchro rings? why would you double clutch???
Old 10-05-2015, 04:27 PM   #9
Yaristeve
Perhaps... ... because it is fun? Especially during heel-and-toe downshifts through corners...
Synchros or not, double clutching makes for smoother downshifting under certain conditions if done correctly.
Old 11-05-2015, 11:02 PM   #10
Lux
Lux's Avatar
Drives: NCP91
It is a force of habit from my old 4Runner and Supra gearboxes whose synchroniser assemblies were significantly worn. The double-clutch rev-match forgoes the reliance on friction against the synchroniser blocker rings to match the input shaft speed with the output and counter shafts.
In doing this, pushing the shift lever into the gates during a downshift requires, literally, almost no effort, with only a cunt hair of resistance from the shift rod detents. Mind you, my Yaris gearbox still sees significant and frequent abuse.
My upshifts are still normal "granny shifting" and is the only time my synchronisers are being used.
Old 09-14-2015, 06:24 PM   #11
428CobraJet
Drives: '09 Yaris 3dr, 13 F150rcsb 5.0
134,000 miles.
Original. As new.
You are what you drive.
428CobraJet is offline   Reply With Quote
Old 09-14-2015, 09:11 PM   #12
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
2009
Just died under 100k (changed clusters, can't recall the difference)
Replacing with a Clutch Masters FX300 series.
I don't do a very good job of rev matching when downshifting into corners, so I've dramatically shortened the life of the OEM unit. Started slipping about 3 weeks ago, completely shit the bed on the way to work this morning. Would have replaced it when I swapped gearboxes last summer, but didn't have the funds. Now I still don't have the funds, but have to get to work. The MR2 isn't really a commuter vehicle and needs LOTS of engine work to be reliable.
Old 09-15-2015, 04:40 PM   #13
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Year: 2007
Miles: 81,000
Original clutch? No.
Clutch replaced at 23,000 miles with TRD unit; was covered under warranty and I paid the $40 (yes, $40) upcharge to go from stock to TRD.
Still has some clutch shudder in first gear.
Old 09-15-2015, 08:40 PM   #14
IllusionX
Drives: 07 Yaris Sedan Aero
2007, bought of october 2006.
156000km
Studders when cold, 1st and 2nd.
Original clutch
Sent from my A0001 using Tapatalk
Old 09-15-2015, 10:53 PM   #15
attrapereves
When you guys mention studder or chatter, when should I feel this? When pressing in the clutch pedal or releasing it?
Old 09-15-2015, 10:59 PM   #16
Foot
Drives: 2010 3dr yaris
Releasing it, I have about 45000 miles and it has been doing that the last 10000 miles or so on the second take off in the morning. I am not concerned though.
Foot is offline   Reply With Quote
Old 09-24-2015, 07:33 PM   #17
CrankyOldMan
Update: Driven about 40 miles on the stage 3 clutch. Wow. I didn't realize how much power I was losing to clutch slip until this bad Larry went on. Hooks up almost immediately, puts ALL the power down. Even makes the tires hop on bumpy roads when accelerating. I would describe the pedal feel as firmer than stock, but not uncomfortably so. I wouldn't want anything heavier for stop and go traffic, but this should do just fine for AutoX and spirited driving.
Old 09-24-2015, 09:55 PM   #18
tmontague
tmontague's Avatar
143,500km original clutch, bought car used w/ 87,000km on it so no idea how the clutch was treated prior.
The clutch shudders when cold in first gear, but no slip yet. I'll be bleeding the clutch within the next few months. I'm teaching my fiancee how to driive stick this upcoming summer so i'll be buying a good aftermarket clutch to install once she learns to install at the end of next summer.
I can't stand the feel of the stock clutch.
Getting Rid of the infamous Clutch "Shudder" tmontague DIY / Maintenance / Service 14 07-08-2023 01:56 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 03:48 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
