Old 07-08-2017, 10:14 AM   #1
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Where are you mounting your AEM FI/C ??
The boomslang harness is not very long...are you pretty much stuck with mounting the AEM on top of the factory ecu?
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-09-2017, 06:53 PM   #2
SirDigby
Drives: 2007 yaris 3 door
in the trash can!
j/k
i'd go with the infinity, mounted in the stock ECU location; when i add the turbocharger.
Old 07-09-2017, 07:34 PM   #3
malibuguy
Obsessed with 1.5L
Im glad you have the money to drop on an Infinity.
Plus it will not pass OBD2
-96 Tercel 4dr
Old 07-10-2017, 09:07 PM   #4
SirDigby
why would it not pass?
i figure if i'm spending $3000 on an upgrade, i should spend the $2500 to make it run correctly. this is just my opinion. i believe you do things right, or you don't do them at all.
Old 07-10-2017, 10:47 PM   #5
tmontague
tmontague's Avatar
assuming the infinity is a standalone, most etests now use the obdII port to check for engine readiness. standalone=no obdII=etest fail
This is the biggest obstacle for us wanting to go boosted on a yaris who have to pass e tests. (another big reason I chose to do a 2zr swap)
Old 07-11-2017, 10:29 PM   #6
SirDigby
yeah i'm checking on that now. i thought the infinity had obd output....
Old 07-12-2017, 08:58 AM   #7
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Most stand alone ECUs do, but that doesn't make them emissions compliant. Non of them will control the charcoal canister or monitor catilytic efficiency.
Old 07-13-2017, 12:53 AM   #8
SirDigby
meh. i don't think they check that around here. the plug the car in and check readyness codes. it takes 10 seconds. then they test the fuel cap for integrity, it takes like 20 seconds....
Old 07-11-2017, 11:13 PM   #9
malibuguy
Obsessed with 1.5L
Where are you getting 3000 for an upgrade?
Beauty of being a fabricator and getting parts at the right time for a good price. Ill be spending probably more getting the car tuned then actual money in the parts of the build.
6 years in the making not in any particular rush
-96 Tercel 4dr
Old 07-13-2017, 01:14 AM   #10
SirDigby
pistons= $600
connecting rods= $600
rings, pins, bearings, seals, crank balance, etc.= +$500
camshafts=+ $600
valves, retainers, springs, etc. (shims?)= +$500
head work= +30hrs.
block= $200(?)
total= $3000 + 30hrs. head work
then, i guess you need to purchase your turbocharger and the components for that.
turbocharger= $800 (a Good one)
intercooler= $200
plumbing (air)= $500 (+,++)
plumbing (oil)= $200 (+,++)
extras= $100 (+,++)
total=$1800 for turbocharger
(ECU= $2500)
oh, LSD=$1800
probably need the brake upgrade= $250
so, total=$9350
i guess my $3000 was way off. sorry, i'll pay more attention.
Old 02-28-2018, 01:44 PM   #11
malibuguy
Obsessed with 1.5L
pistons= $600
camshafts=+ $600
head work= +30hrs.
block= $200(?)
intercooler= $200
extras= $100 (+,++)
(ECU= $2500)
oh, LSD=$1800
so, total=$9350
LOL
-96 Tercel 4dr
Old 07-11-2017, 11:16 PM   #12
malibuguy
Obsessed with 1.5L
The intercooler core was the most expensive part and I got it below retail :p
-96 Tercel 4dr
Old 09-23-2017, 03:26 PM   #13
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
ive always wanted to put mine in the glovebox in a plexi illuminated case along with the factory ecu.
Sent from my LG-H918 using Tapatalk
DarkShadowFox is offline   Reply With Quote
Old 02-28-2018, 08:05 AM   #14
hichamaziz
Drives: my car is the best
hichamaziz is offline   Reply With Quote
Old 03-09-2018, 11:58 PM   #15
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
I have the Camcon.....Yet its still in the box. I just don't trust any tuners, nor do I beleive a few more horsepower is worth the risk.
So I still run the factory ECM and an n/a engine :-|
Old 03-10-2018, 09:32 AM   #16
tmontague
tmontague's Avatar
This is the thought that keeps me sticking with my factory ecu whenever my brain wanders into the realm of a piggyback. I don't plan on going boosted and realistically I don't want to fill up with premium since it my DD'er. In the end my net gain in hp would be virtually negligable, not worth the risk of a bad tune blowing the engine
VVTi Control with AEM EMS-4 Question(s) KTS Performance Modifications 8 01-01-2015 09:30 PM
FS: AEM FI/C unit and Boomslang PnP harness DKN-YARIS Items for Sale by private party 0 06-12-2013 04:33 PM
aem EMS-4 standalone ECU maxthehax Forced Induction Forum 19 05-23-2013 12:29 PM
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 03:03 PM
FS: Zage Turbo kit, AEM FIC with Pnp Harness djgab101 Items for Sale by private party 32 04-11-2013 11:42 AM
