![]() ![]() Drives: 2008 Yaris Join Date: Sep 2014
Electronics randomly not working - NEED HELP!
So I had a thread going from the other week - http://www.yarisworld.com/forums/showthread.php?t=55721 . It was about how my vent fan has seemingly began to stop working. Some start ups it will be fine, some times it won't work but will randomly turn on in the middle of the drive. The other night a swift punch to the dash seemed to be enough to make it work. Now, my dome light stopped working. I thought that somehow the bulb blew or something and that I should change it. The next day I noticed that it was working. Last night it wasn't. Today it is. I have no idea if the problems are correlated but I can't help but wonder if the random not working is too coincidental. And if they are correlated then I have to assume, given how things have been working, that the problem is only going to get worse. I've never experienced something like this before and have no idea where to start looking, someone pplleeease help!
Have you owned your car since it was new? It almost sounds like it has taken a bath at some point and is now suffering from corroded connections.
^ Used. He bought it last year. I would also suspect it has had a questionable past.
is this your car?
https://www.youtube.com/watch?v=JKgT4z7gasI |
#5 | |
I doubt its the battery. Like CTScott mentioned this seems more like a connection issue. If it's working/not working/working again that sounds like a loose wire somewhere making intermittent contact. Could be the power supply or the ground wire. Things like this are usually a royal pain to chase down. Good luck.
| vent fan randomly not working | scoobopdan | DIY / Maintenance / Service | 12 | 12-10-2015 03:15 PM |
| Remote Fob and Stereo Stopped Working after Fuse Change | Ruud | DIY / Maintenance / Service | 6 | 03-12-2015 08:15 PM |
| Basic Electronics Help Needed !! | Ferret_san | Off-topic / Other Cars / Everything else Discussions | 13 | 05-30-2009 10:35 PM |
| Valet 712t not working | yaris prime | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 04-23-2009 07:53 PM |
