![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
Cleaning throttle body help!!
Can someone please guide me the steps to get access and clean the throttle body?
I looked under the hood and tried to figure out how to get the wire harness with the blue colour plug out of the way, but can't find a way to do it. As you can see, i slipped out the 'A' hose but still have no idea what next.
Well D un-snaps from B. (Look close and you should be able to find where to press on D to release catch and pull off). If you follow the wrapping of D's wires to the plastic clamp holding it to E, that clamp can be un-snapped from underneath and the intact clamp holding the wires can be lifted. Detaching hoses should be straight forward. Try building a fixture to do all that when you add a short ram intake. I had to in order to keep things in the stock position and give it a clean look. Anyway hope this helps.
So that means A, C, D and the plastic clamp will be disconnected, but everything else intact?
Thanks |
OK!! Fixed!
Got it out and cleaned! THANKS |
Good. Hope I helped.
i followed your instruction to get access to the TB!
after cleaning TB and MAF sensor... my car runs a lot smoother!! it revs faster now, like when i first bought the car. i've never done it before since new, the car has 120,000km. to anyone who wish to do this, i suggest you do it cuz you will see deposits on both TB and MAF, not a lot but it affects the performance and mpg of the vehicle! |
![]() Drives: Yaris 2D 2007 Join Date: Aug 2011
May I know how and what you use to clean the TB, thanks...
I used TB cleaner, people say carb cleaner also works but i worry that it damages gaskets..
You just get the intake out of the way, then turn the key to ON position and get something heavy to hold down the gas pedal. This will open the valve in the TB, and you spray some TB cleaner(not too much) area you see dirty, wipe off with rag. After that, if you get the check engine light, just disconnect the battery for a few hours(or overnight), and connect it back it will reset everything. Bought a twin pack from local auto shop
Thank you.... caineroad
![]() Drives: 3 dr 1.3 2NZ Join Date: Dec 2008
Realized this is an old thread, but can I reach throttle body by just unscrewing F and clean it from there? When my aircon is on, the engine sometimes sputter and dies while on idle.
Yes. You can access it pretty well just by disconnecting the intake hose. You will still want to open the butterfly to clean the inside as well. With the ignition on (but engine off) either wedge something against the gas pedal or have a helper press it to keep the throttle open for cleaning.
#12 | |
That was 15,000km ago and I noticed lately that my car seems to idle around 500RPM and then I can feel a slight rumble and it will rise up briefly to 600 and then back down. I wouldn't necessarily call it a "rough idle" but it is noticeable while being stopped most of the time. Anyone know the recommended cleaning interval for the TB? I'm surprised if a dirty TB is what is causing this issue since I cleaned it not that long ago. I'm also using an oil catch can FWIW. |
#13 | |
#14 | |
![]() Drives: Toyota Yaris 2012 Join Date: Jan 2016
Low rpm
Hi. I wanted to know if you were able to solve the low rpm problem? I am having the same problem in my Yaris. Cleaning the throttle body doesn't seem to solve the problem. Can you advise if ever you know the solution. |
The issue ended up being a vacuum leak coming from m oil catch can. Once I sealed that it went away and the idle normalized.
Use a code reader and check the short and long term fuel trims to check for vacuum leaks.
| vitz high idle problem after cleaning the throttle body. | dindy | DIY / Maintenance / Service | 20 | 11-07-2012 06:05 PM |
| Mass Air Flow Sensor & Throttle Body Cleaning | Damian B | DIY / Maintenance / Service | 11 | 09-24-2012 12:00 AM |
| Cleaning throttle body | ToTo | Performance Modifications | 18 | 07-27-2011 06:20 PM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 09:52 PM |
| Toyota Throttle Body Spacer: the Best Fuel-Saving Device | davidmills | Performance Modifications | 1 | 07-02-2007 12:38 AM |
