Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > NY / NJ/ CT / PA
Old 11-01-2014, 07:50 AM   #1
Shoshinru
Drives: 2014 3dr. Liftback
Triler hitch wiring
I plan on towing a small utility trailer and need to install a hitch. Curt makes a hitch that fits but what model trailer wiring convertor will work? Any help will be appreciated.
Shoshinru is offline   Reply With Quote
Old 11-01-2014, 08:53 AM   #2
I just installed the Curt hitch on my 09 and I used the Curt 56175 taillight converter.
Old 11-03-2014, 10:31 PM   #3
Eduardo_mty
can i use this with my 2015 yaris hatchaback?
Eduardo_mty is offline   Reply With Quote
Old 11-03-2014, 11:39 PM   #4
Yes. That one will work with your 2015 as well.
For the 2015:
Tail Light left and right: Green
Brake Light left and right: Light Blue
Turn Signal Left: Yellow
Turn Signal Right: Sky Blue
Ground: White/black
Old 11-03-2014, 11:56 PM   #5
Eduardo_mty
Thank you CTScott
Old 11-04-2014, 05:27 PM   #6
Eduardo_mty
i bougth the curt wiring kit.....
one question... i will need the male or female plug to connect together.
which is the name of that plug to search on ebay or amazon
Old 11-04-2014, 06:40 PM   #7
The car side (the one that is included in the curt harness) has three female and one male pins and the trailer side has the opposite. The connector is just called a 4 pin flat trailer connector.
In this picture the trailer is on the bottom:
Old 11-04-2014, 06:56 PM   #8
Eduardo_mty
thank you CTScott,
i will buy any brand, only need 4 flat pin connector
Old 07-23-2015, 05:11 PM   #9
Eduardo_mty
One doubt, i bought this lights.
I will install on a cargo Carrier.
Wires config
Black = ground
Yellow = turn light
Green = tail
Red =stop
White = reverse
How i will connected to Stop works, at this time do not work
Old 07-23-2015, 05:15 PM   #10
Eduardo_mty
Size:  58.1 KBName:  uploadfromtaptalk1437682508679.jpg
Old 07-23-2015, 05:16 PM   #11
Eduardo_mty
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 11:06 AM
Genuine Toyota Hitch for Yaris now available in Canada voodoo22 DIY / Maintenance / Service 8 04-22-2014 08:50 AM
Trailer hitch wiring yaris 2012 Strider199 Third Gen Yaris General Discussion 16 04-15-2012 08:00 PM
Trailer Hitch Wiring bldunne General Yaris / Vitz Discussion 1 01-30-2009 05:10 PM
hitch wiring hell twixt DIY / Maintenance / Service 9 06-02-2007 01:27 AM
