![]() ![]() Drives: yaris sedan Join Date: Oct 2008
Engine noise
I am getting this strange noise when starting my car. It mostly happens in the morning or when leaving work in the evening.
Any advice what can be causing this noise? I attached a link with a recording of the noise. https://soundcloud.com/faraaz-khan-13/engine-noise-2 |
![]() ![]() Drives: 2007 toyota yaris sedan Join Date: Jun 2015
The noise? That like cricket noise? Might be that serpentine belt check if its old. Hows the condition.
When was the last time it was changed. The belt that goes on all the pulleys. |
it sounds like a scraping/squealing noise.
This was changed about 2 months ago. Same noise before and after. |
![]() ![]() Drives: 2007 Toyota Yaris LB Join Date: Mar 2007
Year and Mile of the car?
Some new belts make noise too.
And I'm serious. Give it time to break in. How tight is it? I don't think it's loose but new parts do need time to break in. Give it a month or two. Hey it was that cricket sound right? When the car turns over and starts to run right. I think the noise might be from friction from a new belt. Don't tighten anything like the incredible hulk. I'm not saying to retighten just let it relax on it's own. Some new parts need to be broken in on their own. Who put it in?. |
It's a 2008 yaris sedan. The mileage is about 140000 km.
It's not the cricket sound. Sent from my iPhone using Tapatalk |
Is it constant?
It's more like a very short whistle screeching noise for a quarter of a second after the car finally turns over? Does the sound go away after this and during driving? . |
#8 | |
Yes, it a short screeching noise. Which goes away far start up. I do not hear it while driving. |
Who put in the belt?
How's the tension? Get it adjusted if needed. |
I got it installed by a local service station. This was done about two months ago. It was carried back last week for tensioning. Noise didn't change.
Drives: Yaris Sedan Core AT 2010 Join Date: Mar 2016
Did you find the cause of this noise? I'm having the very same problem. Belt's tension looks good to me although, I haven't changed it in a while.
#12 | |
http://www.yarisworld.com/forums/showthread.php?t=55661 Mine has been making the same exact noise for a while now. Others have commented on my YouTube about having the same noise. Neither Toyota nor a highly yelp rated local shop were able to diagnose. Best guess was the starter sticking when cold. |
![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
could it be one of those common toyota VVT start up noises? plenty of examples on the tube.
![]() ![]() Drives: Want a yaris Join Date: May 2012
Sounds like the starter solenoid sticking just a bit too long. Common problem in corollas/matrixes/vibes. Sounds very similar. My wife's 10 vibe has had this intermittently since we bought the car.
One thing that may help- only bump the key forward and let the car start itself. Don't hold the key forward until the car starts. |
#16 | |
| Toyota's new subcompact will use Mazda's Skyactiv engine | Kal-El | Off-topic / Other Cars / Everything else Discussions | 43 | 03-25-2014 01:01 AM |
| Yaris 2007 engine noise / vibrations | vincentg | DIY / Maintenance / Service | 2 | 06-29-2013 10:03 PM |
| Speakers make noise when engine is on | Lafiro | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 01-07-2009 08:52 PM |
| engine noise?? | poshi | General Yaris / Vitz Discussion | 23 | 09-04-2006 10:45 PM |
